ive also seen you several times at planet, i drive a silver 33 with a carbon gt wing and rear diffuser and hard off set wheels.
i saw your 33 there this arvo and instantly remembered it from your description - stood in the middle of the carpark just perving on those offsets for a while before heading in to the gym :P saw rysith's v-spec there again too
spotted STYLN r34 gtt 4 door in cardiff today
looking nice with the kit on!
btw anyone keen for the Nelson bay cruise sat?
can you PM me the details man :)
Hey guys who went to Nelson Bay today. Cheers for meeting up with Brent and I in Newi. Was good to meet everyone.
Was kinda unimpressed when we left Bar Beach carpark when pretty much everyone gave it some up onto the main rd spinning. I know it wasn't much more than a few of you revving and spining up your wheels a bit but I copped a whole lot of shit from the woman walking past while I was waiting for traffic when I didn't have any intention to rev or spin my wheels. Go ahead and give it some onto the highways during the cruise etc but through town (especially at a carpark where a lot of people are running, walking, doing exercise) and to these people they just instantly label us all as hoons, it doesn't really prove anything to anyone. Sorry guys that's just how I felt :D So next time if we could keep that to a minimum I think everyone will be happy :cool:
-Jimmy.
yeah your right Jimmy it wasn't a good thing
it looks bad for all of us even though clearly u were driving sensibly yet that lady spewed at u. I guess when they see a low car with a bucket seat and stickers etc to some people, the driver automatically looks like a hoon.
i will mention this to the boys
cheers for the notice Jimmy
i spotted a R32 gtr on the freeway heading north bound around 5.18
spotted a series 1 r33 on Brisbane water drive
and spotted woody ( central coast person) turning into his street ..... Hai
Got a wave from a black 34 (sedan i think) on Woy Woy Road at Kariong
was behind a silver 33 turning on to Central Coast Highway and while sitting at the lights spotted a sweet looking M35 stagea going the other way
spotted a couple of days ago the gunmetal R35 gtr at kariong shell... got sum pics on my phone of it JIZZ lmao then it took off n i passed out!!! lmao
Hey fellow coasties,
I need some work done on the r33 could you please PM me info on good workshops or which ones to avoid in the gosford area? Thanks heaps
Also spotted/drove passed a accident on manns road a week back red r33 front end damage, bad luck man hope you and the car are ok.
cheers Rich
spotted 2 stags
one last night at ourimbah ...... past it everytime going the oppsite way lol
spotted the other one at the light on henrry pearry dr
and spotted a R32 going thought charmhaven
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
