Hold on a sec, you got the clutch when? Have you bedded it in? (approx 1000km/s)
Ie. ride it in a bit for the first 1000km before you start launching it....
  • Replies 49
Also, who installed the clutch? I'd be making some calls on Monday, sorry to hear it's died so soon after you bought it, post some updates once you find out what happened...
Bit early to be launching/thrashing the clutch Anthony, as Gareth has stated you are supposed to bed them in.
A number of things could have caused this fault:
- Wear and tear on gear box
- Excessive thrashing
- Bad clutch
- Poor installation
- etc.
Do not assume it's the installation that is always at fault as more times than not, it's not. Ring the mechanic on Monday and explain, in a calm manner, what has happened and how soon they could look at it.
  • 9 months later...
Nismo twin plate coppermix. I have the competition model which is rated a little higher with the Nismo Slave cylinder. I will NEVER change it for something else. It's behind a 400 rwkw 2.8 litre. Cant recommend it highly enough.
+1 Piggaz. If you have the money, this really is the clutch that most 300rwkw+ owners should have under their left foot.. Absolutely fantastic it is...
I had my clutch installed yesterday (ORC700) bought/imported brand new and installed at a local workshop who said they have done at least 6 of the exact clutch with no problems. However mine is the exception. When I turned up they didn't know I was there and I heard them say: "One of the nicest R32 GTRs I've driven very tight, the clutch still isn't right though. Just give it back to the customer." :D Bloke turns around and says: "this is the customer". "Oh is this your car? Now I want you to try it for a week..." Me: "Um, I think I'll take it back when it's working properly thanks".
It won't go into gear on idle properly, extremely hard and has to be jammed in. Now they are going to pull the box out again, as they said they have checked all adjustment items leaving only the throw out bearing as the issue - which ironically as I turned up the person who installed it complained of how difficult the job was to do in this regard - or as he said: "if our work ends up being fine and it's the clutch itself, then we'll talk". WTF is that supposed to mean? It's brand new! Anyone know how the clutch itself could cause this? Sounds potentially like a throw out alignment issue to me...?
Needed to vent!
709D? maybe they haven't used the correct throwout bearing and carrier.. I gave the correct ones to my mechanical workshop when they went to fit my clutch, bit of a discussion regarding wether what I had selected was right, they went for a different one.. had to go back to what I selected.
Somewhere I have my copy of the orc manual with my handwritten notes on it if you want to check the part numbers. maybe not on this comp cos I'm in the boonies, but might have access to it.
Yeah it's the 709D. That could also be the case. Either that or it isn't aligned properly...? I certainly won't be paying if it's not right and they blame the brand new clutch (bloke on the phone yesterday was hinting toward that). They said they have done several of these exact clutches before, the bloke who is there being the reason I took it there, who has a history of GTRs, said that there shouldn't be any issues but someone who did their apprenticeship at a Toyota dealership was the one working on it and complaining. I would be grateful if you can give me the part number as the person installing it complained it was more difficult than others they had done.
Recently upgraded to a Jim Berry 'Carbon Special' I am rather happy with the results, stock car atm tho :P For the money i had spent for the JB vs the same money on an off the shelf after market item i have got a far superior clutch that in theory should well outlast the off the shelf item. Oh, i went from a twin coppermix to a single :D
If you ever feel the need to talk random car 'Stuff' call Jim Berry and have a coffee handy, he likes to talk and ask ALOT of questions about what you want, he wants to make sure you are getting what you need and likes to explain how the rotational axis of the earth has a small efffect on the random engagement of the clutch at X amount of rpm lol
Good luck with the clutch endeavours :D
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
