Yeah it's for your own good. Don't show up without one.
So can I use cable ties to fix the bracket of the extinguisher to the seat rail adjustment bracket thingy or does it need to be fixed to the car in a special way?
I was gonna just leave the thing in the glovebox hehe but cable ties are sufficient yeah?
  • Replies 166
Posted Images
Cams handbook says it must be bolted (not even tech screwed) to the body. Probably just a good idea to do it properly once? Do a search, I'm sure people have published their simple solutions.
it aint getting screwed no where. its a new farken car. cable ties it is, Chris let me know before Saturday if this is gonna be an issue!
Dave I understand you don't want to drill holes in your new car, and we don't expect you to, but your going to need to come up with something slightly more creative than cable ties. Sorry.
It needs to be securly fastened to the car somewhere.....
Can I suggest that you look around inside your car for somewhere there is an existing bolt. Such as seat rail, seat belt anchor point, centre console mount mounts, just something that you can remove and existing bolt, then replace the bolt back in it's spot with the extinguisher bracket in between. You may need some oversized washers to get this done, or you may need to drill a slightly bigger hole in the fire extinguisher bracket.
The way a lot of us do it in the GTR's is to remove the bolt where the rear lower seat mounts to the body of the car, and put the bracket between this bolt and the body. If you imagine you were a rear passenger this bolt would be touching your calf muscle. (back of your lower leg) See if the taxi has something like that.
Good luck.
edit.
yep. thats right. gtr's eat grass and you dont make friends with flannel.
I beg to differ, Leigh and I made mates with the course car guys at Sandown cause they thought our matching flannies were funny. You never know frysy, I might just have a little present for you this weekend, just for being a nice guy.
Surely that would put it out of reach for the driver, defeating the purpose? Its a big taxi remember?
In the fraud the front seats fwd/back adjustment is a thick metal bar that goes from one rail to the other, I was gonna use some big fark off cable ties to fix the bracket there. I'll try a D-Shackle or similar type bolt around the same bar. Either way, I'll ensure there is a metal fastener being used somehow.
Edited by miniwog
Proposed running order for Saturday
Please let me know today if anyone wants to be in the same group as someone else.
Entrant # Name Car Drive
1 Ryan's Bell SILEIGHTY RWD
2 Gary Mathews WRX AWD
3 Tim Williamson R32GTST RWD
4 Ben Winston R32GTR AWD
5 Mat Cross CORONA RWD
6 Matthew Femino R32GTR AWD
7 Nick Edlin R33GTST RWD
8 Mark Firman 180B RWD
9 Greg Calmer SILVIA RWD
10 Sam Zimbler LIBERTY AWD
11 Jarrod Moore SILEIGHTY RWD
12 Alycia Mathews WRX AWD
13 Mick Eichorn R32GTST RWD
14 Troy Galt 1600 RWD
15 Jamie Lovett 911RS RWD
16 Alan Calleja R33GTST RWD
17 David Sidebottom 1200 RWD
18 Nicholas O'dowd WRX AWD
19 Che Boocock R33GTST RWD
20 Bart Kohler R32GTR AWD
21 Antony Ivancic R33GTST RWD
22 Martin Sullivan S14200SX RWD
23 Simon Lesniak S15200SX RWD
24 Dean Taylor EVO8MR AWD
25 Chris Thomson R33GTR AWD
26 James Ward EVO10 AWD
27 Chris Stacey R33GTR AWD
28 Aaron Foo EVO9 AWD
29 Jack Kuzior R33GTR AWD
30 Dinesh Rodrigo MX5T RWD
31 Mark Homer 944S2 RWD
32 Dave Marinucci XR6T RWD
33 Gareth Anderson R33GTR AWD
34 Matty Bray R32GTST RWD
35 Allan-Paul Ravell R32GTST4d RWD
36 Andrew Richmond R34GTR AWD
37 Steven Strekovski MX5 RWD
38 Iain Thomson FORESTER AWD
39 Stephen Hugh-Smith SUPRATT RWD
40 Jake Radzikowski 180SX RWD
41 Daniel Chin R34GTT RWD
42 Simon Baxter R32GTST4D RWD
43 Khoa Nguyen TOYOTA AWD
44 James Constable EVO9 AWD
45 Alexander Girsang R33GTR AWD
46 Shane Janssen GTR AWD
47 Tom Giordano R32GTST RWD
48 Alex Jovanovic PUG306 FWD
49 Ryan Verner WRX AWD
50 Adrian Mueller WRX AWD
just got some practice in, a few mistakes here and there... but thought i'd film it, keep you guys in the loop of my prep...
don't mind the car, just my thrash about practice car :D
http://video.kenblockracing.com/flash/smal...&autoplay=0
:down:
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
