LSD's have a higher diff ratio i thought? and makes taking off from the lights much faster.. also the obious will always get power down to both wheels rather then just dumping the clutch to just get 1 spinning.. and getting rolled by a car with a lsd off the line..
thats my understanding anyways.. i would go a gtst diff i hear those things are tuff.. keep in mind if u get different ratios ur speedo will be off so might need to get that recalibrated..
Leigh
https://www.sau.com.au/forums/topic/241625-lsd/#findComment-4217729
if you do a burnout with a non lsd car on grass it may still spin both wheels. even on cement it may still spin both wheels. my old falcon had an open centre diff and i did a burnout on the driveway and it spun both wheels.
the most reliable way to check is to jack up the back wheels and turn 1 wheel. if the other wheel turns the same way as the wheel you are turning then it is an LSD, if it turns the opposite way then it is open centre.
https://www.sau.com.au/forums/topic/241625-lsd/#findComment-4222400
if i wanted to make it lsd for 2 wheel spinner, wohat would i get, gtst lsd? orr?
If you get an entire LSD unit from a GTS-t then it will have a lower final drive ratio. You'll lose acceleration in-gear, although each gear will stretch to a higher speed.
Not particularly recommended, unless you find that you could do with a bit more speed in each gear.
I'm pretty sure that Skylines have the speedo sensor coming out of the gearbox, so changing your final drive affects your speedo reading.
What are the advantages of having a LSD ?
In Nik's case, when you rip a skid you're more likely to leave two black marks on the road instead of one.
From a technical standpoint, you're less likely to break traction on one wheel as power is sent to the other that isn't slipping. With an open diff, power flows through the path of least resistance. If one wheel starts to slip, it gets more power. This means it slips more, and the wheel that isn't spinning gets less. Eventual scenario is that the free spinning wheel ends up getting all the power and the other wheel that has grip just sits there doing nothing.
A diff in a turbo car will nearly always have a lower final drive ratio than its NA counterpart if the displacements are the same. With less torque, the NA engine has to be kept up in its rev range while the FI car can use the extra midrange oomph from the compressor to make up for it.
https://www.sau.com.au/forums/topic/241625-lsd/#findComment-4230377
  • 2 months later...
i had a guy at the tranny shop say tht if it goes the opposite its an lsd so i jacked it up when i was working on it and did it and they went the same then when i finally got it on the road (completly gutless mind you and there were no cars around) i sidestepped it only chirped and felt like my side then when i went and did a skid both were going then when i got off the brake and held my foot flat it did two little drifts then died ????
my gearing is really really tall what speed does first gear normally get you?
Edited by LUME
https://www.sau.com.au/forums/topic/241625-lsd/#findComment-4380151
is there any visual differences? like the fins or sumthing when ever my car drives in the wet or if i rip one it slides almost instantly and if i did a burn out it left 2 black even lines, so do i have lsd? or just a lock diff?
https://www.sau.com.au/forums/topic/241625-lsd/#findComment-4382659
how about a mini-spool, would this affect the gear ratios...
It doesn't affect gear ratios as the construction of your differential is independent of the ratios. The ratio for each gear in the gearbox is obviously unaffected.
Inside the differential is a final drive gear, which affects your actual speed relative to the engine speed in each gear. This gear has a certain ratio. You can make it any ratio you want (within reason), so whether you keep it stock or change it is up to you.
and is it good/bad?
A mini-spool is a locked differential. Both your driven wheels will spin at the same rate, no matter what. It's great if you just want dry weather traction above all else, especially in a straight line. Track cars, like drag cars V8 Supercars, run fully locked diffs (but they'll probably use a full spool since it's stronger).
The bad sides are that the car will understeer more, you'll skip the inside tyre around bends so life is reduced, and since both wheels spin the same way chances are both will break traction at the same time. That can be problematic in the wet.
If you must have a fully locked diff, I'd suggest a "Detroit Locker" instead. While under power it behaves like a completely locked diff, but when not on the throttle it unlocks. That means that you can coast through a corner without chirping the inside tyre, or spinning out in the wet.
It's a very compromise kind of system. Tearing up to a bend and turning in with a reasonable amount of speed so you can coast through it, and not touching the gas until you're practically straight, can make you look like a bit of a git. Since it goes from fully open to fully locked the transition can unsettle the balance of the car if you get on the gas before you get it reasonably straight.
If you were building a drag car that you had to street drive to the venue I'd suggest it. Otherwise, I just don't see it as being a particularly good idea.
https://www.sau.com.au/forums/topic/241625-lsd/#findComment-4386858
Of the cars ive driven with mini spools and even welded diffs, wet/dry condition, neither are all that bad, as long as you are aware that you are in fact driving a car with a locker and dont try to be a hero around corners in the wet, its fine. Even in my mates S2 rx7, which isnt exactly heavy in the arse end. with a welded diff is fine in the wet and that diff has been welded for around 2.5 years.
Obvously an lsd would be a much better option by far, but getting the welder out can be a good way to learn how a car behaves when boths wheels are spinning evenly.
https://www.sau.com.au/forums/topic/241625-lsd/#findComment-4386895
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
