heloo.
i have been tying to install Nismo R34 GTR cluster in my GT,
most all working accept the speedometer end the central door lock.
engine Waring light : error speed sensor. is it possible to get pic of how it the cables are connected.
regards CB
  • 2 years later...
  • 8 months later...
  • 2 years later...
  • 6 months later...
  • 2 months later...
I have just completed this conversion and have updated the Excel document. I found an error on it and also added a few missing pin outs.GTR_Guage_Cluster_Conversion3.xls I can confirm everything works on my car, it is a GTT manual. The centre plug at the back of the cluster is different between GTT and GTR. The GTT is a brown 24 pin plug and does not plug into the white GTR 24 pin socket, I modified mine to fit using a hacksaw blade and needle file. I also swapped the lense over to the GTR cluster for the Slip and TCS off lights.
  • Like 2
  • 1 month later...
  • 5 months later...
On 19/07/2013 at 8:06 AM, camperbob said:
heloo.
regards CB
Hey i know its a looogshot but did you ever figure it out becuse i havet the same problem
  • 4 weeks later...
  • 5 months later...
14 minutes ago, NZ-GTT said:
Nice work! How did you remove the pins from the connector blocks? I could not get mine out so I had to cut and solder wires.
a pin from the opposite side the wires hang out. through the inside hole.  i did this January 3, 2016 from my previous post date. the pictures are from then
  • 3 weeks later...
  • 2 months later...
  • 4 months later...
Oops good pick up! I just rechecked my pinouts and it should be 10 to 9 and 63 to 11. I've corrected the error and uploaded the file in this post as version 4.
GTR_Guage_Cluster_Conversion4.xls
Thanks for the correction!
Another thing, non gtr pin 17 and pin 46 both move to non gtr pin 57.
Can you check if it is correct?
pin 17 is rear defog signal and pin 46 is charge w.l
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
