Have just had my car tunned 98 GTR
list of mod
steel wheel turbos
HKS evc boost controller
Hard intake and cooler piping
cooling pro fmic 80mm
tomei fuel reg
std injectors
std afm
std fuel pump
manifolds
std dumps
3" fronts
3" exhaust straight threw atm
lightened flywheel 12lbs
pfc
cam gears
after tune got 260awkw with injectors at 96% duty and didnt want to push them any harder had fuel pressure bumped up to 70psi running 1.25bar have included dyno sheet.
is this a good tune? have read others dyno resaults and some getting 300awkw on std injectors why are mine maxed out?
https://www.sau.com.au/forums/topic/241868-gtr-dyno-tune-260kw125bar/
list of mod
steel wheel turbos
tomei fuel reg
std injectors
std afm
std fuel pump
manifolds
std dumps
3" fronts
pfc
cam gears
Try running less boost and more timing. And are you sure the tuner wasn't just winding in the fuel to compensate for a dying pump? Maybe a new pump might help to keep things in order. But without seeing the car, it's anyones guess really.
I did not read this before.. but I agree your fuel pump needs upgrading.
I would also replace injectors with new 550-700cc depends what you want to achive and headroom.
Replacing old parts for new is a good thing and a safe thing to do.
std fuel pump
Hey,
It should be easy to figure out whether the pump's not up to the task - get a graph of
fuel pressure on one of those runs (or have someone watch a gauge if it's in the engine bay),
if it falls off at maximum flow your pump needs help.
Regards,
Saliya
I also think dying fuel pump.
Silly to bump the rail pressure without checking the pump is ok first.
Very dangerous infact as in a few weeks the pump could be in even worse state then you'll really have more drama's
Seems a little low..
Stock turbos, injectors, no gears, just exhaust/dumps & power FC made me 250kw at 12 psi.
That’s actually a little high… 250rwkw is generally a result of 1bar.
fuel pump seemed fine i watched the gauge and held pressure strong but at 85psi its was bouncey on the gauge so that why we wound it back to 70 and when on a dyno run it woundnt drop back down or the neddle wounldnt go bouncey at all. but i have just bought a 044 im setting up a swell pot in the boot because i do hill climbs but really dont wanna drive 400km to get another tune on it already have already drop $1000 into tuning it.
when put this new fuel pump in will it stuff up all the a/f ratios?
Very much a potential yes.
If your running a higher than stock fuel pressure to counteract a dying pump
And then put the new pump in, you could find that its running even more pressure = bad.
Ha, yeah they need to learn how to scale their graphs a little better...
Did you run a flow test on it? No point having pressure if you got no flow.
Of course the a/f will be affected, if people are running 280 maxxing the injectors out, and if yours are on 96% then you technically should have almost 280kw worth of fuel going into it with a decent pump.
and theres no way you get 260AWkw running standard turbos and under a bar HAHA.
well he said "steel wheel turbos" not standard turbos. (or did you mean someone else?) certainly my 32 n1s give me about the same at 0.8 bar which is all we are allowed to run.
travis we make very similar power in our targa car at 0.8 bar using standard injectors, standard fuel pump, standard afms etc. we are also running over 90% duty cycle which is high enough for me considering how the car is used (no point pushing it to a dangerous level when fuel quality and temperature can vary so much). Not sure where these 280 or 300kw numbers are coming from standard injectors unless maybe they mean rwkw not 4wkw?
definately check the fuel pump is OK to be safe but we don't get any more than you do with new pump, clean and tested injectors and nismo adjustable fpr. easy to check since it sounds like you have a fuel pressure gauge - pressure should climb with boost right to the top of the rev range...if it drops off up high you have fuel pump or fuel pump wiring problems
yes i noticed it to that it only goes to 140kph, the tunner said something that it wasnt getting traction would this be the case and he said his rollers where warn? i will be putting a swell pot in and a 044 pump and i re-run the wiring aswell.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
