Burr we would of cleaned up if we were eligible against general Sydney entry ;)
YAY! :( Like I said after the show, I WILL be organising duplicates of the trophies for anyone that wants one. A LOT of effort was put in by A LOT of people and I want them to remember that weekend :( The cost will be known on Tuesday/Wednesday hopefully :)
I'm getting some pretty gnarly headspins right now due to lack of food, sleep and rest, so I'll probably be heading off to bed shortly.
WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOt
  • Replies 241
Posted Images
pfft
we had a better display, and we SO had more power then you :( though we were worried... we were watching you closely ;)
I might organise it next year with the other states so we just enter as SAU country wide :(
Morph you guys had a nice display over there but in the power stakes well, only 4 of our cars went on the dyno(mine managed a terribly low score btw) and we still won the club shootout :P
I think we both got hard done by Queen Street Racing even BEING a club as really, they are part of a business.
Oh well, there's always next time.
Display looked awesome guys.
Spoke with Marijan the other day and he was really pleased with the weekend.
A bit down that he didn't get any individual awards but got over it pretty quick :-)
He went for a bit of a drive on the Sunday and got pulled over. Luckily no defects, but the nice polite lady officer, took his phone number and address saying she might send him a nice invite to visit the EPA :-)
He tried arguing that his exhaust was called a HKS Silent so there's no way it should be too loud but didn't get very far.
Hahahahaha I love the way he thinks :/
A car like that should really be engineered, I hope he's done that.
To be honest, we were all a bit peeved he didn't win best engine bay, especially after one of the judges was drooling over it... The winning one wasn't even finished! It seems shiny things impress these judges :/
Luckily I stayed back to help pack up and didn't go for a drive with Marijan. It would have been a riot trying to argue the 'HKS Silent' exhaust excuse on my car :/
And I agree that Marijan's engine bay should have won best engine bay (not that I am biased in any way :/). Pure street car that has practical show and go.
Best. R32. GTR. ever.
Well done to Marijan on such a fine example of a true street/strip/show car.
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
