Hey all, im looking at buying a whole new kit for my 33, i was wondering if those who have new kits if they could post em up so i can see what there all like and make a decision, right now im looking at the new do luck one, but id like to see whats out there! pictures please
cheers
https://www.sau.com.au/forums/topic/241982-body-kits/
cheers
I'm a fan of the M-Sports kits. There not to over the top, nice smooth kit. I dont really have any good photos worth posting but hopefully someone can post some up cause id be interested to see as well
Have a look at DMDtheimage website
theyve got a few nice ones
https://www.sau.com.au/forums/topic/241982-body-kits/#findComment-4221346
i have this one on my car only the front is top secret modified and d-wing. :(
I hope you have a nice set of wheels with some good offset... LOL!
Those stock rims have to go, does not suite your body kit. :)
https://www.sau.com.au/forums/topic/241982-body-kits/#findComment-4235112
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
