Tomei dumps are 75mm so unless your front pipes are also 75mm(rare), they are a waste.
However we regularly see up to (and over) 400 rwkw with std dumps.
Have also done back to back tests at 360- 380rwkw with the ONLY change being the dumps and there was NO measurable difference.
We have done this test backwards and forwards several times now (fitting them and removing them, big pipes , little pipes) and again NO measurable difference.
Hard to believe as the std stuff looks like crap, but results are results.
On -7's and 300kw, its not even a consideration imo.
Actually this is the one you want if you like HKS GTSS RB26 performance , everyone everywhere thinks these ARE GTSS turbos with Garrett actuators . Compare the comp maps to the other suggested turbo .
A .
http://www.turbobygarrett.com/turbobygarre...0R_707160_9.htm
http://www.turbobygarrett.com/turbobygarre...0R_707160_7.htm
Edited by discopotato03
not much differance between the 2?
In the real world, there is virtually nothing seperating these 2 (-7 or -9) in terms of power. (both can top out north of 350rwkw)
If anything, the slightly "friendlier" comp wheel on the -7 may spool marginally better than the -9 (SS)...but it is almost too close to call.
You will get great results with either.
The GTSS do come with 1 bar actuators, as do -5s
However -7's come with 11lb actuators (as they are intended to be a bolt in std replacement) which are a bit lamo for the higher boost applications.
It is advisable to upgrade them to the 1 bar actuators if you intend to wind em up past 20lb
Edited by RPMGTR
Well up to you you but if you look closely at the "islands" and the percentage numbers I know which in theory is going to blow slightly cooler air .
Also if you run your eyes up the vertical 30 Lb line to where it intersects the most RHS island note the difference .
It looks to me like the -9's wheel/housing combination is happy to pump air at low pressures as well as high making them a slightly better all round combination . I think these would ultimately make better mid range torque than the -7's .
When you look at HKS spec Garrett turbos you start to see minor alterations to Garretts off the shelf compressors and turbines and they only tend to use non Garrett housings if they found it made a significant difference .
With the -9 cartridge they obviously saw the need to make changes to the compressor wheel otherwise they wouldn't have bothered . I suspect Garrett use their off the shelf wheel rather than alter things because that's a cheaper way to make a generic turbocharger - she'll be right .
IMO HKS went to a bit more trouble to fine tune something to suit a specific application - they wanted the response because people hate turbine lag and they wanted torque to make the engine pull hard without big revs .
All these turbos are really trying hard to alter the state of tune of RB26's , a 4-8 power range is a bit hard for some to stomach in a road car so possibly 3-7 is nicer on the street .
Your calls , I would buy the turbo fine tuned for the app particularly now that you can buy them from Garrett at a Garrett price .
A .
Oh and by the way , Garrett obviously did a cut and paste with the turbine map on that -9 blurbe page because alterations to the compressor side should show up on the turbine map . Lazy pricks .
Ahh thanks for that info; i will be buying the hks kit now as it comes with the better actuators, I was going to buy the -7's.
yep, the HKS kit used to be top value as it includes all the gaskets you need (good qual multi-layer metal ones) and turbos with the heavy duty adjustable actuators pre-fitted and set at 1bar. and all the other little nuts and studs you need and inlet gaskets etc. but sadly it's just gone up a fair bit due to the AUD weakness, but if you can find a kit here you can possible still get it at a competetive price. plus you get the HKS turbos too which are nice.
sounds good but i would definately go the -7s for street use and you may wanna go for a pair of rb25 afm, they are cheaper and you can achieve 400awkw just a thought...:P Eveything else seems good..
im currently at 306kw on stock afms and GT-SS or -9's.... why replace parts if they arnt maxed out? as Benno and Ash are saying about the stock dumps and cams.
i have HPI dumps but my cams are stock and im not going to change them.
yeah you can live without the cams, and if you decide you want them later they can easily be fitted in the car. so no need to buy them now.
I would get the dumps. whilst everything is out and your doing the turbos give them the best breathing you can. the tomei dumps are good and match well with the big boy twin 75mm HKS front pipes.
afms, well same as the cams. you don't HAVE to get them now, and if you find out you do need them they are only a 30 min job to fit down the track. you probably will though. I was regularly hitting 5.115v on mine stock GTR AFMS at only 276rwkw. sure you can still get quite a good tune even with maxed afms, but it's nice to have more scope for more airflow to be measured there.
whilst your engine is out also consider doing sump baffles or a sump extension. good idea if you plan on any track use in the future. and impossible to do with engine in the car.
Like BeerBaron said, afm's take stuff all to change. I had map sensors fitted to my intake while the motor was being rebuilt, just in case i decide to use them in the future. they are simply blocked up for now. the highest ive seen on my afms is around 4.500v. if they ever show that they are maxed out, then i would look at replacing them or maybe looking at the map sensors.
Hmm interestign thread. Thanks guys.
Another option would be to sell the Power FC and get a plug-in Vipec (see the Vipec thread). I've just fitted one to my Stagea 260RS and it's running off a MAP sensor and has brilliant idle control and only took a few hours for the installer to tune. That way you don't need to worry about AFMs at all. Plus it has boost control, launch control and knock control (if you add a signal amplifier).
Does the motor have to come out to fit a set of turbos or dump pipes???? Or am i misunderstanding?
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
