  • Replies 177
Posted Images
speaking of bumps chris I didn't bump into you today. did you get a day off? enjoying a quick spa maybe?
I wish i had a spa...but then I'd have to find 11 friends to enjoy it. and I don't think my girlfriend would be too happy sharing a spa with so many other girls :blink:
And to answer your question, YES I HAD THE DAY OFF!!! :) weekends rock when u don't have to work, you should try it sometime.
So the spa is still standing out the front of the house? or has it been moved yet? by the way..the current local time is 5:38pm and the weather looks quite good :P
Edited by ChrisCross
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
