I going to be taking the head off next week and I might as well get a thicker head gasket for my R33..
My current mods are Power FC, HKS2530kai turbo, Z32 AFM, FMIC, Custom TuneAgent Exhaust manifold and split dump pipe 3", Bosche 023 fuel pump, Im running around 18psi boost, and I wanna be on the safe side and get a thicker head gasket.
What size/type is recommended to suit an RB25DET?
Also, are there any gasket kits available for an RB25DET, including intake plenum gasket etc??
Cheers.
https://www.sau.com.au/forums/topic/243921-head-gasket-question-for-r33/
hi mate,
a 86mm would probably be best, by 1.5mm
Im going to use a 87mm x 1.2mm head gasket
you can buy genuine complete nissan gasket kits for around $200
for example, lewis engines sell head gaskets and gasket kits http://www.lewisengines.com.au/category2_3.htm
although better prices can be found on the net
example : http://shop.rawbrokerage.com/category.sc?categoryId=20
edit: I ended up buying a heap of gear for the head from Erics Performance Parts, usa ebay, when the usa $ was 1.03$ to the aussie dollar so made it quite a cheap buy-up exercise
mind you, my complete rb25det head job will set me back around $4500
I wouldnt go bigger with that setup. All you will do is lose a little response.
But if you want to upgrade the gasket to a metal one you cant go past Cometic for Price and quality.
I would recommend the 1.2 or 1.3mm.
As for gasket kits i just bought one from Andrew at Kudos Motorsport here on the forum, cheapest ive found.
yep Cometic is the brand name Ive chosen for the gasket set(s)
good pricing and excellent quality in the flesh.
must admit I stole that website link from ntsky, =) always have a look there, nice site
you can read about my head work here:
http://www.skylinesaustralia.com/forums/He...&hl=tangles
Thanks for the prompt reply guys, Tangles thats a nice list of items you have there for your head work. :P
I think I'll end up going with the 1.2mm by 86mm.
Another thing that I was told was that I might need to get new head bolts as the old ones might be stretched at wont tension properly once put back in place? Is this true? Or do I just re-use the standard/old ones?
Simple answer, no.
Taking the head off and taking the engine out are two different ball games. Also its a waste of money for the power your going to be pushing, stock internals will be fine.
So i would have to get the engine out, the RB25 oil sump isnt bolted on the bottom?
out of curiosity why is the head coming off?
what power is it pushing?
Long story short, there is a hole behind one of the exhaust manifold studs and its leaking oil.. the reason the hole is there is because a mechanic drilled through there to get a broken stud out and ended up drilling through the block into the oil gallery, so im taking it off to get it welded as i have tried to use sealers and everything else and nothing has worked so far..
so i thought i might as well change the head gasket along with the rest of the intake gaskets etc. while the head is off..
power at the moment is 230rwkw @ 20psi with HKS2530kai, this is why im getting a thicker metal head gasket as well..
Edited by EVL-R33
You want to build a motor with the block still in the car....
Also no need to go a thicker metal head gasket, your choice though. When i take my head off in a few weeks im just replacing mine with the standard nissan one in the engine gasket kit. No reason to lower compression at these power levels.
incredible, i know a guy that had the same thing happen, re the exhaust studs/drilling into head.
however he made the mechanic pay for the f**kup, took it to another mechanic and got the first one to pick up the tab for head removal and all other associated repairs/parts.
mistakes happen, but the story i got told was it was a bit of a mess once he was done.
The place I will be putting in the pistons has a hoist so if the sump comes off, it will save some time and i wont have to get the engine out... but if the RB25 sumps dont come off then obviously i will have to take the engine out..
I was told differently, to actually lower the compression a little so i would be able to run more boost (20-25psi) because these turbos can produce it and my current application can handle it. The gasket which i ordered is a 1.2mm by 87mm, so its not too thick...
wow, so im not the only one that it has happened to... the mechanic has paid for his mistakes which was good.
do you know how he ended up fixing his? or did he actually get it welded like what im going to do?
PS> Sorry for double posting, but i dont know how to delete posts on here..
Edited by EVL-R33
Not sure if a 2530 will be much efficient mast 20psi.....
not really big power figures im after at the moment, just wanna have peace of mind, running over 20psi with a stock head gasket is a bit scary at times... i will be in the market for a bigger turbo in the next couple of months anyways...
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
