Hi everyone.
Well recently i had an rb26 cylinder head flowed to see what it flowed intake verse exhaust. To say i was supprised how poorly the exhaust flowed compared to the intake would be an understatment.
Now the specs on the head in question are as follows, and theres a few pics of the ports/chambers too:
Tomei Cams - 270deg 10.8mm inlet 280deg 10.8mm exhaust
Tomei cam gears
Tomei cam cap studs
Supertech manganese guides
Supertech Valves - 1mm in 1mm ex
Supertech dual springs and titanium retainers
JHH labour - port & polish, clean & assemble
JHH custom shims (for smaller base circle cams)
JHH custom inner spring seat
johnshead013bu2.th.jpgjohnshead008ee8.th.jpgjohnshead010qs9.th.jpgjohnshead011tg1.th.jpgjohnshead012fp4.th.jpg
The entire head work was performed by John Hill Engineering in brisbane.
The point of this thread is to have a discussion on what these figures mean in terms of i spose power delivery & boost response etc, to discuss how the head could be optimised to get more even flow between the 2 sides by either more/different port work, different valve combo etc, and how different cam profiles will affect the real life power delivery and boost response.
Also for those of you who have done some back to back flow testing with different head specs, if you could shed some light of your finidings that would be fantastic.
Shane
https://www.sau.com.au/forums/topic/245266-rb26-head-flow-figures/
Yeh i asked the guys about the different testing methods and they said it all boils down to what depth the test is done at. The std depth is 28". And you can see on the printouts my test was done ay 28" so should be comparable to other tests done at the same depth.
Some other figures i've seen of the std head are 148cfm inlet & 105cfm exhaust, but theres no details of how the test was performed
When I think back to Grade 10 high school chemistry, I recall that chemically combining compounds resulted in products with significantly changed physical properties. This includes their molecular weights and densities. The same concept applies to burning fuel in your engine via the 4-stroke process.
My recall is now not as good, but if you know the chemical composition of your petrol it is possible to work through a few chemical equations to get an idea of the difference in total combined molecular mass pre and post-combustion. High school chemistry will only get you so far though, and engineers are a quantum step beyond that.
Engineers know that when designing and sizing different aspects of your 26DE head they need to factor in what it takes to shift gases that will change their physical properties during combustion. Therefore you will always see inlet valves and ports bigger/better flowing than the exhaust.
Provided your flow bench has shown a measurable improvement from stock to modified, you have had some sort of a win.
Ohh shii, well it looks like you've used a top of the line tester (compared to what we did anyway)
when i saw this machine it looked like something that was taken from the since lab at school about 20 years ago :P
it was simply a bot that made alot of noise with some nobs and some slides that could shut off the air and some red liquid gauge that went up and down...
^^ well depending on how you look at it porting can increase lag...
When you open up an area, it takes longer to fill (exhaust side talking here).
Obviously there is more to it than just that, intake side lets more air in and so on
But its an interesting concept and very much a black art at times.
well i've had confirmation from another very experienced head guy and he said this head should be able make the 750bhp we're chasing, his opinion was that the way the exhaust currently flows that it'll take a bit longer to spool the turbo and it'll take some more boost to make the hp than it would if the exhaust flowed more
keep the discussion going :banana:
shouldnt the engine having to do less work to get the air/fuel in and the exhaust out negate that?
well thats where the theory comes into play, but remember theory doesn't always workout in the real world and vice versa...
Would be good to hear from some builders on it all (that have tested etc) as i'm just theorising as you are
I have a Newish r34 gtr head. Before it gets started on (if its not already in pieces) I'll take it to my friends shop and throw it on his dinosaur flow bench. and then when its complete i will do the same. might take a photo of the dinosaur too.
would be ok to compare before and after results which is what my friend does with VW heads he works on. but i dont think comparing to other benches would be ok.
I've done a bit of backyard head porting on my old 2 litre pinto powered rs2000 based on books from David Vizard on these motors (I made twice the rwhp with stock rejetted carby, inlet mani and aftermarket cam with same duration as stock).
Based on his testing its the shape of the ports that dictates flow and velocity rather than the shear size. From memory he said it was the quarter of an inch before and after the valve that was most critical.
Also wouldn't the larger exhaust valves and ports enable the exhaust gasses escape more quickly (one less bottleneck) and hence result in less exhaust gas residue in the cylinder....thereby reducing the possibility of detonation and/or being able to run more advance to assist in earlier spool.
My 2c
My 2c
Negating the size of the valves etc, and without looking in my fluid dynamics books increasing the exhaust valve port (i.e. increasing cross sectional area) will decrease the velocity of the gases (assuming a constant mass flow rate of gases). It is just a question of what is more desirable in head design.
I would think larger inlet ports (to allow a larger volume of air) and a polished smooth exhaust port of smaller cross section (to allow the exhaust gases to flow at high velocity with the least amount of restriction possible) would be somewhere on the right track.
But "larger" and "smaller" are just words there would be a considerable amount of calculations involved to optimise the inlet and exhaust ports.
Very interesting topic.
Mike
well bear in mind they can be flow tested a number of different ways. often they suck air through which is different to blowing air through. also, bear in mind things change quite a bit once boost is entered into the equation. head porting design is still a bit of a dark art an outright flow numbers don't really tell the whole story. the real proff of good head/bad head will be how it performs once it's on the engine. from here it's all guessing. :D it does look nice though...
I agree with what you've said on the basis you've assumed a constant mass flow rate. The issue is at what point do we need to improve the mass flow rate because it becomes a bottleneck in which case larger ex valves are required to ensure exhaust gas residue in the cylinder doesn't overly taint the fresh incoming charge. The answer to this question will be dictated by the intended application, rev range etc. I tend to think boost and intake manifolds will take care of the intake side of things to a point.
Returning back to my backyard porting I installed larger flat back and narrowed stem intake and ex valves in my Pinto motor with no loss in torque through the mid range and good hp gains throughout the rev range.
Incidently, I recently had my SR20 head also done by JHH and also went with 1mm oversize Supertech inconel ex valves. The port and chamber modifactions largely resemble the pics of RB head in this thread. My build is nearing completion so I can't comment on the affects of the head work at this time.
I spoke at length with Will from jhh earlier today and i'm quite confident this head is as near perfect.
From what he was saying, its not about getting the largest cfm rating possible, its about port design and taking meat out of the right areas.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
