I am in the process of building an RB30/26 and have my RB26 Block, CP 86.5mm pistons and std rods with ARP rod bolts up for grabs. I have pulled the block right down to confirm it's all in good order. The motor has done around 5-10,000km's since it was rebuilt. The block and crank were both prepped by ADVAN.
Specs are:
1.5mm oil restrictor
decked
oil return galaries enlarged
additional support to turbo oil outlet(most crack and leak coolant, very common)
86.5mm bores
Balanced Crank
Linished
Plus the usual ADVAN prep
rebalanced and prepped std rods
Both the motor and block are stamped and numbered by ADVAN. I'm sure ADVAN can bring up all the specs on there computer if you want to find out more, i'm sure there are other things they have done that I haven't listed.
I would fit new rings ,but, you could get away with the current ones if your on a budget. Good for 380rwkw no problems.
Includes
Block
Water pump
Crank
Craddle
Windage trays
CP forged pistons, rings, pins, clips(still assembled on rods)
Std Rods with ARP rod bolts
Located in Adelaide
Avail: next few days
Price: $1000 the lot
SMS or call 0413023669
or PM
oh, it's cheap...I've been out of the loop
happy to sell it quickly to pay for my new build.
I can arrange rings at cost
My Mechanic rang and recommended the rod bushes be changed also
I can arrange postage anywhere in Australia for a great rate door to door
can also arrange new bush, bearings, and rings fitted with block cross hatched ready to go at cost.
btw DANOOH has first dibs.
then in order of messages on my phone I guess
I won't be on mobile till after 1600 Adelaide time
Regards,
Matt
PS feel free to email me
[email protected] before 1600 today
Edited by BoostdR
Oh, it's also from a 1998 Series 3 Vspec.
i can give you the chassis number, engine number if you would like to confirm with the Nissan Fast software.
cheers.
Not really Adrian, i know Matt, but i also know that Pete doesnt enlarge oil galleries, use oil gallery restrictors or balance standard rods and cranks, hence the reason i asked
Your right he personally doesn't, he out sources those bits to be completed to his specs.
Anywho it's sold and paid for
Just for the record, Peter has not balanced any part of this engine, he has not enlarged oil return galleries nor fitted after market oil restrictors, i should know, i helped put this motor together. Peter does not believe it is needed when putting an engine together.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
