my car is giving me nightmares!!! no one can fix the bucket of shit...it will not pull on boost it just breaks down and has a shit fit and wen u clutch it it goes into limp mode,but in the wet it arcs up fine...wont rev over 5500 rpm and i need help bad!! could this be a faulty knock sensor or somthing?
https://www.sau.com.au/forums/topic/245778-rb25det/
well the car has one of them aftermarket plenum and it was not sealed properly so it got removed and powdercoated and then put bak on and this upset the power fc and it will not run the car anymore.so it has a stock ecu running the car now.it has new coil packs and plugs i have a bosh pump but its not yet in the car.
https://www.sau.com.au/forums/topic/245778-rb25det/#findComment-4274779
if it was a stocker id say def coil packs.. could still be the case but obviously the thing has been played with so maybe something else..
if it arcs up in the wet it might be because your not loading the car up therfore not as much boost getting pumped through it hense not shitting itself.. thats what makes me think coilpacks
https://www.sau.com.au/forums/topic/245778-rb25det/#findComment-4278780
its been to geelong tuneups before i bought it...looks like its goin bak lol umm the plenum wasent sealed properly in the first place thats why the power fc has a bad tune to counter airleaks and so on...this is the information that has been handed on to me as i know f*k all about jap cars.the car has new coil packs in it and does blow a lil blackish smoke on idle.
https://www.sau.com.au/forums/topic/245778-rb25det/#findComment-4281453
If the power fc was tuned to counter airleaks and now you have a plenum with no leaks, then a re-tune will fix your problems. Also black smoke is ok, just means the tune is a bit rich, probably stuffed from when you changed the plenum. I recently cracked my intercooler and now it leaks which stuffed my tune the same as yours. Now it blows black smoke too cos its running rich. Its blue smoke that you want to look out for, blue is never good.
Hope that made sense. Good luck with the car mate
https://www.sau.com.au/forums/topic/245778-rb25det/#findComment-4283677
Yeah i guess it should but im not really a fan of stock tunes so i would still suggest a re-tune of the power fc. You may be surprised how many problems a good tune can fix. Also could have something else wrong with the car such as coilpacks or old sparkplugs which are the usual suspects for making rb25's run like shit.
https://www.sau.com.au/forums/topic/245778-rb25det/#findComment-4284051
if its a standard car then a std ecu will work just fine..........if you have a forward facing plenum, a fmic, and/or turbo, injectors, pods, etc etc then a std ecu can't help you. The pfc is a tunable ecu, it is your best option.
https://www.sau.com.au/forums/topic/245778-rb25det/#findComment-4284854
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
