Offered up the rear Brembo callipers from an R33 to my R32 GT-R last night.
Problem being the hoses from the 33 are too short to connect properly. Also the hoses from the 32 have a different end connection (block mount) to the 33. So I cant just swap stuff over.
So the question is this:
Anyone that has done this conversion what did you use for hoses. I there a 32 Vspec hose package with a block end connection or are they all the same & connect striaght into the calliper? :D
Edited by djr81
https://www.sau.com.au/forums/topic/245783-r32-rear-brembo-issue/
Strange. I have aftermarket braided rear lines and they screwed into the GTR caliper no problem. So sinc emy aftermarket GTSt lines worked, i assume then the std GTSt lines would work. I would also expect that the GTR are the same as well. I did modify the bracket that they all mount to the caliper like the R33 lines do, but i wasnt supplied any of the std R33 lines so just made my GTSt ones fit
So the lines you have go straight into the calliper? No stuffing about with blocks & hard piping?
The line would fit but the 33 is approx 30mm shorter than what it needs to be.
As an aside the bolts that attach the rear Brembos are M10x30 with a 1.5mm pitch.
The bolts that attach the rear Sumitomo's are M10x30 with a 1.25mm pitch.
You have to go to a proper bolt shop as the Champion packs you find at most auto parts shops start at M10x35.
Photos:
Brembo first.
Sumitomo second.
Edited by djr81
Have pretty much done the same. Sent the old rubber hose off to Perth Brake Parts with an instruction to make it the same, just 30mm longer.
As an aside (another one) the pads I got for the F40 callipers are listed as "BA Falcon Fronts from the 4 pot calliper" - presumably a Brembo item aswell. They have what I took to be a slot for a pad wear indicator. Is there another common car that uses a similar pad but minus the slot for the indicator?
Edited by djr81
the problem is with your front callipers. they are no good. send them, and the calliper mounts to me and I will dispose of them safely for you mate. wouldn't want anything bad to happen to you. I care.
Thanks mate. :O Do you need me to cover you for any expenses or will a carton of Crownies surfice?
I asked the nice folk at Racer Industries what a 345x32 2 part front rotor was worth. Answer:$1k. Per side. Ow, ow, ow. So am staying with 324's for a long, long time....
Edited by djr81
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
