Just a little curious over this one..
Lots of people seem to be selling their skylines at the moment (including me :) ). After a bit of a lull, there are a stack of skylines that seem to be going up forsale at the moment. In VIC, there is about 10 skylines i could probably name that have been put up for sale recently or been sold. Why exactly?
1. People cashing in while they can still get good money for modified cars with the new RAWS system?
2. Some of the younger guys are realising how much it actually costs to keep a skyline on the road after owning one for 6-12 months?
3. People need money for other things such as houses, etc.
4. Insurance costs are going up too much and cops getting to heavy on imports?
5. People want more rice, cheaper TCO and things rather than pure power these days.
I guess mine is a bit of a mix between 1 and 3.. what about everybody else?
https://www.sau.com.au/forums/topic/24601-why-the-sales/
well, my hubby lost his licence for a year so we decided to sell his GTR - no point keeping it sitting in the garage for a year. I've been driving it but it uses so much fuel! It's just a waste sitting there depreciating in the garage. He'll most likely get another one later when he gets his licence back next year
https://www.sau.com.au/forums/topic/24601-why-the-sales/#findComment-524287
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
