  • Replies 448
Posted Images
i wouldnt worry, especially what the 'judges' think. put a BMW badge on ur car, call it a conversion, then u too can win an award for unnecessary shit on ur car.
that would be assuming were all going there to try and win an award, pretty sure most of us would just be there for the fun of the day.
thats what im assuming. the award bit that is. seeing as its preferred that my non skyline doesnt enter on the day.
that being said, im not too fussed. if im not too dead from work ill probably pop by and say hello. :huh:
Edited by scandyflick
look if u want to whinge and bitch about then go ahead........but not in my thread please. this is a SKYLINES AUSTRALIA CLUB DISPLAY......and funnily enough i dont see silvia written anywhere in that title.........
skylines only thanks.
if u dont like it then go start ur own club display.
i might not even own the car by then Cara so thats why not entering, there is something in the pipelines at the moment.
And i cant believe your letting Dave work you up, DAVE! the biggest shit stirrer of all lol.
So I take it there will be no Stagea's then?
Given that they are no more a Skyline than the Silvia. (just stirring LOL)
I have to agree with guy. Even tho this is >S<au, theres no reason why u cant make it a nissan performance vehicle stand
hell you could even have 4wd if they werent toyotas (sorry matty)...
its like me trying to get a display for GTR's only. Badges dont make the car great; loads of skylines that aint gtr's that kick arse over mine. its more so what the owner decides to do with the vehicle. And thats why an NA 34 can win shitloads of awards, because the owner knows how to give the car a hellified pair of boobs n booty >_<
Skylines, Silvias, Soarers, Rexs, Stags.... theyre all good platforms. Show some love baby! :bunny:
-D
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
