Hey,
Have a few left over from a recent group buy.
They are Brushed Stainless Steel dash inserts.
They come with Heat treated Double sided tape so it won't unstick in the heat at all.
$75 del to you.
PM or email me [email protected]
cheers
Rob
https://www.sau.com.au/forums/topic/246268-aftermarket-brushed-ss-dash-insert/
wow I was just asking about these where to buy them in another thread .. Do these fit R34 GTT ? If so I'll take one ! If not, can you please tell me where you got it from ???
Hey,
These SS dash inserts will fit a R32 GTR and a R32 GTS-T.
I'm not sure if they sell R34 GTT SS inserts or not. If not they can buy will atleast need an order of 10 to make it worth while.
Cheers
Rob
Hey,
They are through a friend of mine you has a Engineering business and happens to have a CNC cutter. So if there is enough interest I will make the arrangements for the ten to get made up.
Cheers
Rob
If I can get enough interest I would get the R34 dash inserts made up. 10 group buy of the SS. Can you send me a pic of the R34 GTT dash?
thats not a R34 gtt dash Damo
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
