twin high mount is only possible befor monday this wkend, i just need a definate by this wkend, otherwise unavailable.
Twin low mount is usually $1400 but now only $1100
Single low/high is $1000
  • Replies 92
yeah i'm in leon,
rb26 high mount single external gate
how much extra for split pulse
Edited by blockasR32
ah man it fits. External gate or wha they will make it to fit. Xmas part at work tonight hada couple of to drink but alritew haha. Yeah if want a rb26nt twin high mount monday is the deadline. otherwise high single or low twins.............. all good, boost will make manifold to almost suit anything
Okay i have messaged mods and no reply but i cant edit any of my posts, its making this group buy difficult, but here is the new list...
1.Choku_dori - RB20/25 high external, sr20 high external - deposit taken
2.Shilohr32gtr - rb26 single high mount - deposit taken
3. wisey18 - R34 RB25DET Stock location, low mount, internal gate - waiting deposit
4. Tamimego - (ns.com) low mount sr20det t28 internal gate - waiting deposit
5. blockasR32 - RB26 Single High mount External gate - deposit taken
6. bigadz - lowmount sr20det manifold standard flange for GT2871R internaly gated - deposit taken
hey
I'm after a high mount manifold with external gate for an rb25/30 (in an r32 gtst). It will have a reasonably large turbo and with the 30 bottom end, the block will sit up 40mm (approx).
I just want to make sure that i wont run into clearance issues with my bonnet with this setup.
Can anyone confirm or advise?
Cheers
What is the cut off dates for deposits?
Once work has started what is the time frame on delivery? Will need some time to scrape some cash together before xmas :)
same here if there is more people will the price go down
it looks like 9 item mite be bought try for ten for a better deal
can he make this
r33 RB25DET Stock location, low mount, internal gate 3037hks pro s turbo
Edited by WARLORD
Not quite sure what you mean by a balancer pipe. But Twin low mounts are $1100. If you want twin high mounts let me know and i can have that arranged, but must be BEFOR monday.
If anyone can help me out in editing my first post would be very appreciated :)
SR20DET High or low internal or external all $800!!!!!!!!!!!!!
The balancer runs from manifold one to manifold two, it helps prevent turbo shuffle by balancing the presure. Heres a pic of DirtGarage's old set up (hope you dont mind Paul)
If they can be added to the group run im interested.
any pics for 26, twin, low, internal?
Bought these from the previous group run.. they are low mount twin RB26 internal gated.
can he make this
Yes that can be done. Cut off date is 14 DEC. Will get manifolds hopefully befor xmas.
Its $40 delivery anywhere in aus.
Ill ask about the balancer pipe.
4age is $800 highmount only.
Once again any mods going to answer my plees for help, ive asked everywhere. How do i edit my first post. I NEED TO!!!!!!
Great thanks mate.
You wont be able to edit it, the mods intorduced it for accountablility (ie scum editing the first post to cover their tracks) the only thing you can do is hit the report button on the post and report it to the mods. In the dialogue box just type in the changes and where you want them to go.
Cheers,
Johno
are you sure he can do it in the stock location as this is the email i got from kyle two weeks ago
""I can't build anything in the stock location mate, there would definately be gains to be had, but there just isn't room to put anything in the stock location. it would require a new dump in either location. Build time would be 2 weeks.""
Kyle
I will call 6boost and talk to them, see what they say. ill pm you back and let you know..
cheers
hi,
Just wondering if you had a chance to ask 6boost about the clearance.
Thanks
Zac
Kyle
Hey,
Thats odd... I just text him and he told me low mount is stock location... He will be on here to reply a post soon, just keep an eye out
I actually met Kyle last night. A "cruise" was organized to Palm Beach.
Some very tough street cars in attendance as you would imagine. I was convinced to get on this group buy lol
So how do i out my deposit down?
Kyle told me i could give him my cheap highmount and he would match the location of the turbo so it would still fit my custom dump. And at no charge i might add.
do you want me to send it direct?
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
