  • Replies 168
Posted Images
Vol 4 - 041 - Asakusa Temple; Shrine (28mm)
Vol 4 - 042 - Fortune Tickets (28mm)
Vol 4 - 043 - Main Shrine (28mm)
Vol 4 - 044 - People Praying - hmmm... not to me (28mm)
Perhaps... to "Great Temple Rabbi" 'er Reincarnated Rabbit?
Vol 4 - 049 - Asakusa Temple; Pagoda (28mm) always with an odd number of rooves whether it be in China or Japan.
Vol 4 - 050 - Sorin (200mm)
Vol 4 - 051 - Kanda Matsuri Festival (28mm) One of the three main Shinto biannual festivals in Tokyo. It started in the 17th century to celebrate a battle victory during the Edo period
Vol 4 - 052 - Kuremutsu Tavern (28mm)
Vol 4 - 053 - Chefs paring a root into extremely thin strips. (28mm)
Vol 4 - 054 - Shinto relics; Circa 1600s (28mm)
Vol 4 - 055 - Relics (28mm)
Vol 4 - 056 - Tokyo Sunset (200mm) - Stayed at New Otani Hotel. I wonder if it's still even there?
Many Thanks Jason - you're very kind.
Film photography with beautiful lenses should still be at least, passable.
Vol 4 - 057 - Tokyo Sunset (400mm)
Vol 4 - 058 - Tokyo Sunset (400mm)
Vol 4 - 059 - Tokyo at Night (28mm)
Vol 4 - 060 - Tokyo at Night (58mm) from my room at the New Otani Hotel
Vol 4 - 061 - New 1975 Technology = Laser Machine at Toshiba Science Institute (28mm)
Vol 4 - 062 - CCTV is now 'brand new' in 1975 lol (16mm)
Vol 4 - 063 - Lamps made large and tiny (28mm)
Vol 4 - 064 - Video Telephone - new in concept 1975 WOW! (28mm)
Vol 4 - 065 - Computerised Operation of Lights (28mm)
Vol 4 - 066 - Electronic Height Indicator (28mm)
Vol 4 - 067 - Tokyo (Narita) Airport Cargo System Computerised (28mm)
Vol 4 - 068 - Train System Computerised (28mm) and Concept of Magnetic Repulsion
Vol 4 - 069 - Computerised Fountain - a marvel of ingenuity in 1975 (28mm)
Vol 4 - 070 - Kawasaki not far from Tokyo (28mm)
Vol 4 - 071 - Tollway Guards wore masks even 35 years ago (28mm)
Vol 4 - 072 - Yokahama not far from Tokyo (28mm)
Vol 4 - 073 - Crops growing in Yokahama (28mm)
Vol 4 - 074 - Kamakura Buddha Complex (28mm)
Vol 4 - 075 - Kamakura Buddha (28mm)
Vol 4 - 076 - Buddha Circa 1252, Weighs 210,000lb, 44' High. (28mm)
As many people have mentioned, its really only the cars and fashion that have changed significantly. All of the temples/shrines/asakusa stalls are pretty much still the same. Japan were the leaders in lighting and all things that blinked/flashed back then too!
Hi Beau, perhaps we can see how some progress has been made through man's intervention. I'll appreciate more feedback about any differences. :rolleyes:
Vol 4 - 077 - Kakamura Buddha (200mm)
Vol 4 - 078 - Inside the head (28mm)
Vol 4 - 079 - Inside the head (28mm)
Vol 4 - 080 - Inside the head (28mm)
Vol 4 - 085 - View from Beach at Kamakura (200mm)
Vol 4 - 086 - Sailing (28mm)
Vol 4 - 087 - Tenement Houses - Rent in 1975 was US$70/month for 2BR
Vol 4 - 088 - Chigasaki Golf Course; US$400/game and Over US$150,000 to join the Club
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
