Has anyone got through with full turbo back exhaust? People telling me I won't pass, but surely its not that loud? Never been picked up on it before. Even the cop that defected me was riding behind me for 5 or so minutes
  Madaz said:
If you had of showed up wednesday i could of measured your car as i had the sound metre in the car
Girlfriend had food poisoning from a nice little place down at Henley, no way was I driving her up to Mawson Lakes.
Is there any workshops that can test for you?
Just put a baffle plate in and walla the zorst will be quiet as
once you pass regency take the baffle plate off and your back to normal
what doesnt seem loud to us will be loud to the DB meter at regency mate
trust me and they will pin you even if your 1db over
so not worth the risk imho mate
good luck with it all
PS i have a r33 cat with baffle plate if you need it mate
  muirsky said:
I'm running a decat atm, so that will definatly have to go. Might have to borrow that cat Krishy. I'll let you know :P
Yep mate i have pm'ed you my mobile number
so just let me know when
So, what's the legalities surrounding battery relocation's?
My current battery is finished and will be investing in a dry cell/gel battery in the near future.
I'm aware that gel/dry cell batteries won't need a vent or anything when they're in the boot, but does this sort of modification need engineering to pass Regency?
The battery would be secured in the boot inside a sealed battery box with a kill-switch.
I think that if you do relocate the battery daniel
then you have to get it inspected
but us 33 owners no such problems
and i dont see why you wont pass that mate
specially if you have a kill switch for it
give sturt cop shop a call and find out mate
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
