What are you talking about then if not shagged street tyres that have gone bald? We clearly aren't talking about racing slicks.
A bald street tyre will perform worse in ALL situations compared to when it was new, there is not one circumstance where it would give more grip.
A racing slick is _completely_ different to a slicked road tyre.
+1
Motorcycle racing is a different kettle of fish, but the same principles apply. I have race tyres with tread (GP rated) which I will throw away after a practice session and a race ... purely because they've "gone off" and lose their grip even with tread left. When I ran slicks (for Supersport) it was the same story. But my road bikes get 6,000kms out of their rubber instead of a few hundred kms. Different environments call for different tyre treads, compounds and profiles.
Scrutineers at a race track will not permit you on track with tyres with low tread/worn rubber ... because the best your tyre will perform is between new to about a few hundred kms old. I've been behind a racer on worn tyres and been covered in bits of rubber, because he had no idea his tyre was disintergrating itself, even in a straight line, at speeds above 160 kph. He crashed later that day.
Slicks are purely bred and manufactured for high grip in race conditions ... does not mean a "bald" street tyre performs the same.
Race motorbikes, then you'll learn how vital tyres are and the differences between brands, treads, compounds, profiles, tyre pressures etc. I take the rubber on my cars as serious as the rubber on my bikes.
+1
what about the 'other' rubber, brother?
-D
Front wheel arch liners, do they have to be there?
One of mine is cut in half and the other is removed. Am I likely to be failed on this? I have no idea where I would get replacements from if so. All the wiring is out of the way and proper shielded so really all they are stopping is mud getting on the inside of the guard.
Edited by Rolls
you can get rory thompson to engineer a lock bar if you need to tho
-D
+1
Rory did a few of my 1600s and my supercharged SR20DE 200B. He can get anything thru. :(
I would pay someone $150 to save me having to change all that shit, hell I'd pay someone to change it all back more than $150.
All he is going to do is look at it on a hoist and verify that it is done properly so you might get away with even less than $150.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
