what he said ^^
emissions test is one thing, youll need to have en engineer hire out a test track for a day and test out the brakes etc etc.
Emissions tests are easy to get past, its the other tests that an engineer has to do that cost a lot more. Best bet is to call up a regency approved engineer and have a chat to him about it.
but if its a bigger turbo and same engine why would you have to change brakes?
From what I recall it's about 345mm eyebrow height (ie: from the middle of the wheel to the guard).
SA Transport document
They've since replaced the document on their website with one with almost no info, so this one should still be good.
Suspension height
The ride height of your vehicle may be
lowered, subject to the following conditions
being met:
• the suspension retains at least two thirds
of its original travel
• the distance between any part of the
vehicle and the ground is not less than
100mm.
The suspension height can be measured
in one of two ways.
>>Source<<
because youre increasing the final power output of the engine and changing the way it behaves. good thing about skylines is that they come with fairly big brakes anyways so a set of good pads/rotors and fluid are usually more than enough.
  • 4 weeks later...
Hey Guys, just copped my first defect for my 33 last night on my way through pt wakefield coming back from a weekend on the YP. only just put a new exhaust on that weekend! coppa looked over my car for a fair while, its pretty much stock besides my 18s zorst and pod filter. after not finding much he eventually deccided my exhaust was too close to the ground and im off to regency.
problem is i will fail and eyebrow height test atm by about 2 cms so need to get hold of some stock springs :blink:
that will probably eliveate my exhaust clearance issue too.
anyone got any lying round??
also anyone been through with 9.5 inch wide rims on the back???
go through with 9.5s and your bound to fail.
also , id just replace the exhaust with a stock system from the cat
thats what i did on mine and i passed with flying colours
your also going to have to do more work on the vehicle to make sure everything else is up to scratch as they will go over the whole car.
also make sure you have an english tyre placard on the vehicle (usually affixed on the drivers side door jam)
chuck stock wheels on , stock exhaust and stock suspension in and you'll pass
yeah, sound advice damage, just lined up some stock rims and i still have the cat back i just took off. hopefully someone has some stock springs lying around and ill be sweet. think i might get my bushes and tie rods ect looked at before i go in just to be sure.
Failed a regency visit recently for a few minor things, anyway I had my car booked into the mechanics today to get my $120 worth of wheel bearings (cbf doing them myself) and $50 worth of child seat anchor points installed, spent $50 on a permit to drive it there as well.
10 mins after I drop it off I get a call "Your car already has child seat anchor points, also your wheel bearings are fine it is just a $40 HICAS arm thats stuffed".
Pretty bloody annoyed, you'd think regency would make sure before writing these things on the notice that you do in fact not have them. Could have had it on the road a month ago as the HICAS arm is a piece of piss to replace, not to mention the wheel bearings and anchor points I now have to sell second hand.
Anyone else had an experience like this? I will be writing a written complain to them about it after I get my car passed, would send it before but I don't want to step on any toes before it gets regod. Is it likely I will get anything other than a mild apology?
Edited by Rolls
try and find a local MP that'll be sympathetic... some of them are biased, but some of them are really good in looking after their constituents
-D
Wouldn't bother complaining to Regency. What the f**k are they going to do? Throw your letter in the bin
If they get enough of them they might do something, I'd like the mechanic who inspected my car to get some feedback however. Maybe if someone tells him he might look a bit harder next time and not waste someone elses time.
I don't really expect them to do anything for my benefit, I just want some heads banged and hopefully some improvements. It can't hurt sending a letter.
i went though with my car yesterday looked over all the car as expected all the initial problems had been rectified which was fine. but he cleared me of everything apart from my headlights, i have the factory zenon hid's for the 34 and they didn’t pass me? is that right, I questioned him and he said they weren’t end of story and was a real wank about it. I said about they newer BMW's n all that with the HID's n all he said was 'well this is a nissan not a bmw' rather annoyed because i was really polite n calm with him n got nothing but a rude old man.
What do you guys think? do i need to now find some non-hid headlights? is it true that there not legal?
Edited by Volk34
The headlights are fine but they have to be fitted with Halogen globes, HIDs are only legal if the car is fitted with auto leveling headlights. BMW = Auto leveling, Skyline = no auto leveling.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
