Rather than start a whole new thread figured i'd ask this here...
Has anyone ever been picked on for having retreads when going through Regency?....Im going tomorrow and I just noticed on my Tire Placard in the fine print that my GTR requires a 'V' Rated tire 240km/h....my intention was to borrow a set of 33 stockies with retreads...has anyone ever been shafted for this?
you will be fine with those mate. As long as the tire has tread and the wheel matches the size stated in your placard you will be fine.
goodluck
Just a quick update, passed inspection today, think i scored the best Inspector there...only down side was I broke the connector off my PFC Hand Controller, I had left it in the car as it wasnt connected and me and the Inpsector exchanged views on the matter...I got a little frustrated and pulled a bit harder than I should have and it broke...exhaust was super quiet, went to 92Db then settled at 86Db...full jap system with metal cat too...wtf? Does have 2 big mufflers...Anyway, im sure it can be fixed, stoked to have passed!
Anyone know anyone that fixes PFC Hand Controllers???...
Any electronics repair business should be able to solder you up a new connector, unless you snapped the actual physical plug itself, might be pretty hard to find a replacement, though any decent electronic technician could wire you up a different plug,
  • 1 month later...
Is the panel firmly attached or does it flap around? If its firmly attached you might be ok, just depends on inspector.
I had my inner guards hacked to pieces, rear bumper loose (they didn't touch it) and front quarter panel had a crack where it mounts and was cable tied on (also didn't touch it), didn't get picked up however none were obvious or loose panels, yours has a hole so it might get picked on.
gday all had my pride and joy defected a few months ago for being 10mm too low and a broken fog light near the underpass of ingle farm shopping centre....was wondering how with the fact of stock springs? as i wasnt driving the car it was a spastic ex that has no clue i couldnt dispute it. and on the subject of fog lights why defect it if you cant use them for city driving? fairly furious and whether i could escape with taking it too elizabeth cop shop?
Edited by gilly_ECR33
Need help asap. Did a final check over the 33 today getting ready for regency in the morning an now as soon as i indicator the hazzards go on.
I have replaced the flasher relay
the fusses
the globes with corect wattige
Have ripped dash apart looking for something earthing i am stuck and have no clue what it could be
345 up front 355 rear got re defected for height today at regency gay not happy so am now after front and rear struts
What height is it now?
I'm a bit worried about mine now too - since I put the 18's on it seems to be sitting around 335 - used to be 345-350-ish :( .. guess I can always put the 17's back on to get through..
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
