Hey Guys,
Just a heads up... I think the boys in blue are doing a crack down as we speak as i have noticed alot of defect stations over the past 2 weeks especially down south near Seaford...
PLUS: when you get pulled over at a defect station on the side of the road, do they pop your bonnet??? I was deffected about a year ago, and they booked me for ride hight and they didn't pop my bonnet but i was thinking as my car is nice and stock on the out side appart from mags and front bar, weather they would pop my bonnet and look for other things???
Cheers
Jamie
Ive been through 5 times and never had to put a stock exhaust system back on.
Last time I went thru I thought it was kinda loud. Turned out fine.
Turbo timer not just disconnected but fully removed.
It's illegal to have a turbo timer installed? How come i can pass a roadworthy with it connected though?
Hey Guys,
Cheers
Jamie
Never mind...
Car is completely stock engine wise...
However, is it illegal to have a front strut brace or a boost gauge mounted just on top of the air vent of the drivers side???
Cheers for your help :worship:
Strut brace fine. Boost gauge no
Depends where the boost gauge is, if its in a vent or down below the dash it is fine, on the dash or a pillar you can't have it though.
Turbo timer is illegal because if you have a crash and the car get a fuel leak and it keeps running, sup massive fire. They shouldn't have given you roadworthy with it connected.
wow didnt know lol thx i went to 3 different mechanics to.. and not 1 picked up on it lol.. guess im lucky then
Edited by nismo07
hey guys i want 2 vehicle identit inspections at lonsdale inspection station i want 2 get my car pass for it 2 be in SA rego because it was from NSW so all the numbers line up so all that pass but they defected me for fibre glass vented bonnet and adjustable coilovers and boost controller.. when
i go back there can they pick on anything other and what they said 2 me to fix ? thanks
Edited by MAD R33
what did you expect lol...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
