lol I will say Search for rb24 :banana:
I have just finished building one myself.
The rods and crank fit, but you need custom pistons and re bore the block to 82 or 83mm depending on the pistons you choose mine went from 1998cc to 2438cc :blush:
26 pistons will never fit a 20 block there is just no point in even stroking a 2L the head ports are not going to flow very well, its like putting a 20 head on a 25 block basically.
better off spending the same money on a 25 and you will end up with more power and a better flowing head and even iv read that it is possible to put 26 crank rods and pistons in a 25 block
cos even if u did get custom pistons thats big money right there, then u need to either hone or rebore, then you need new brg shells all round, different clutch and flywheel, then either a 25 or 26 gearbox, then larger injectors, then engine management, and you still be held back by a shit head.
Edited by BANGN
$300 each? where id u get that from? you dont want to use 4age Pistons, you want to use 4agze pistons as they have ceramic top, 4age pistons wont last long in boosted applications.. i really really hope your not running 4age pistons, even in the 1.6 application they are not advised above 8psi let alone 2.6L of heat and pressure of at least 14psi. 4agze pistons can handle up to 30psi with nos and only then do they start to pose issues
pistons from toyota in australia inc rings pistons and pins are very roughly $150 each retail, ex Toyota - Wellington NZ they are a bit cheaper..
Edited by BANGN
Yeah please search
RB21/RB23/RB24 - its all been covered, parts, what fits/doesnt what options are there etc etc.
End of the day IMO its not worth it because to get the head to flow costs more than a RB25
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
