i was having a look at my dyno from crd today and noticed that my a/f ratio sits at 12.5 and at the last box it dips to 12 ,now is this to lean or is it ok,
the engine has forged pistons ,rods,race bearings apr head studs.
now ive read that it could be unsafe in a stock engine so how about a forged one??
if i run 102 race fuel at the drags will this keep it safer ?
knock is at 16-25 and if i hit the limiter a 65 will come up.
your opinions would be nice if there is someone in the know about a/F ratios and knows rb engines really well it would be nice to hear from them.
thanks .
https://www.sau.com.au/forums/topic/246930-af-ratio/
i forgot to mention that i also was told that when the bonnet is down and on the street that the air flow meter and power fc will make it a bit richer is this true.
that depends on your intake setup....
if you want our opinions on your tune, take a photo/scan the printout and put it up here. 12.5 might be a tad on the lean side depending on the boost/RPM that its at.. 12-12.2 is ideal for WOT on boost.
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4291833
looks a little on the lean side to me... like the above posters said, the scaling on the AFR y-axis makes it hard to see fluctuations and pin point exact AFR's, but it looks like 12.5 dropping to 12 just on redline.....
I think 12 - 12.2 dropping to 11.8-12 by redline is a little safer.. I'd want to know how hot your exhaust temps were getting (this can be used as an indication to what your cylinder tempreature is).
Keep in mind, if you do get them to richen it up a bit, you will lose a bit of power. (maybe 20-30kw ??). In the end, you need to trust your tuner and as far as I know, CRD have a pretty good reputation. Perhaps talk to them a bit about your AFR's and explain what your needs are and see what they have to say. If its for a street-only car, then those AFR's are probably fine as its rare that you do more than the occaisional squirt of WOT.
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4294018
thanks.
as for temps
oil sits at about 70-80 de
water sits at 68-72
and i run the car at the drags with 102 octan
at the end of a run temp is oil 85 water 73
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4294323
yea, those are all fine. I was referring to exhaust gas tempreature - it can be used as an indication of how hot your pistons are getting. the higher octane fuel will give you a bit of overhead as far as timing goes, but as long as the tune isn't knocking, that wont be a problem. If your afr's are too lean, you could melt a piston...
gotta talk to your tuner bro - its important to trust what they have done, or if your not happy with it, discuss it with them further. If your own research disagrees with what your tuner is saying, then i guess you need to find a new tuner. No point in second guessing them...
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4294639
Why oh why do croyden use that afr scaling???
yeah it fking pisses me off. and means you cannot see any changes in AFR unless you get out a microscope. I have no idea what or why they have to hide but it's pretty bad form in my view. and probably not needed either as they certainly have a good reputation for tuning.
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4297070
some times it is impossible to flaten curve to perfection, using that scale makes it internet forum friendly :) safe from know it alls who whould bag a perfectley good tune, but couldnt tune themselves.
i agree it sucks but it probably saves them plenty of headaches.
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4297084
But AFR's dont ever need to be a flat line.
Its the other line that you need the nice smoothness on when drilled down into it
kinda my point, people expect flat lines under power. they should look more like an inverse power curve to some degree.
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4298320
    • I found a supplier for an arm in NZ. https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-rh-side?srsltid=AfmBOopMdfCFDc_8yVZZ9kq5nIngPHRTBzUU8v4SAptJaRO52Wjs0bC6 I looked closely at the photo of that one and the Z1 arm, and it's the same bloody arm. Scratches all match in the photo 😂 How hard is it to change that joint? Also they seem to be listing two options https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-balljoint-rh-side?_pos=1&_sid=229acde44&_ss=r And now I have no idea what size I'd need yay
    • Ill review it again, from memory when I first saw some of Trailer Park Boys I wasn't a huge fan. I ended up at Letter Kenny after watching Shoresy, which is a bit ass backward, ha ha
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
