  • Replies 69
Just spoke to my engine builder about another matter and mentioned your situation. Whether or not detonation/lean mixtures caused the problem, for your engine builder to claim that they did there needs to be clear and irrefutable evidence of same.
If there isn't any evidence of this then it's a cop-out and they're full of shit. If there is evidence of it then you haven't got a leg to stand on.
Isn't he your dentist?
Harris do a lot of RB30's and they're close to you Joe. Worth a call. Although keep in mind they dont like to stay on the phone for long cause they're always busy
Thanks Steve, if the engineer returns with results in my favour then i'll give them a call.
As far as he has told me, he doesnt have an actual report. He says that he's had 2 guys look at it, an engineer (i think) and someone from the NRMA and both said it was caused by detonation whereas the engineer that will provide me with a report said that detonation would not cause the main bearings to go, it would cause the big end bearings to go if anything.
Yep. That's what I would've thought. But here's the thing, dude. It doesn't matter what's caused it, if it has detonated its ring out then there's sweet f**k all you can do.
he said the pistons and rings are fine as well as the bores so i highly doubt it was detonation. the only part in the entire motor that failed were 2 of the main bearings.
Engineer will have a report ready for me by wednesday i hope. i'll ring him today and see if he'll go earlier. no point in speculating if we dont know 100% what happened.
Edited by SECURITY
  • 3 weeks later...
I'm sure Joe will give an update sooner or later, but I understand the engineer confirmed there was nothing wrong with the build, the issue was un-related.
It would be good to see the details posted since the reason I heard was unusual and an interesting warning about how small things can build up to a dead motor
Engineer report in:
results are:
bearing failure caused by overfueling/incomplete combustion + a restriction in the oil pickup which caused low oil flow at high RPM. the over fueling + the oil pickup restriction caused the motor to fail.
I'll post up the engineer report once ive edited out my details etc.
who tuned the new engine? As from what im reading there it has had problems since it was installed as the 8000klms travelled on an overfueled engine. This is critical on initial run-in as an excessively fueled engine will not allow rings to bed-in and the overfueled combustion chamber to release fuel mixture into sump area on compression stroke.
Edited by DiRTgarage
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
