  • Replies 69
Just spoke to my engine builder about another matter and mentioned your situation. Whether or not detonation/lean mixtures caused the problem, for your engine builder to claim that they did there needs to be clear and irrefutable evidence of same.
If there isn't any evidence of this then it's a cop-out and they're full of shit. If there is evidence of it then you haven't got a leg to stand on.
Isn't he your dentist?
Harris do a lot of RB30's and they're close to you Joe. Worth a call. Although keep in mind they dont like to stay on the phone for long cause they're always busy
Thanks Steve, if the engineer returns with results in my favour then i'll give them a call.
As far as he has told me, he doesnt have an actual report. He says that he's had 2 guys look at it, an engineer (i think) and someone from the NRMA and both said it was caused by detonation whereas the engineer that will provide me with a report said that detonation would not cause the main bearings to go, it would cause the big end bearings to go if anything.
Yep. That's what I would've thought. But here's the thing, dude. It doesn't matter what's caused it, if it has detonated its ring out then there's sweet f**k all you can do.
he said the pistons and rings are fine as well as the bores so i highly doubt it was detonation. the only part in the entire motor that failed were 2 of the main bearings.
Engineer will have a report ready for me by wednesday i hope. i'll ring him today and see if he'll go earlier. no point in speculating if we dont know 100% what happened.
Edited by SECURITY
  • 3 weeks later...
I'm sure Joe will give an update sooner or later, but I understand the engineer confirmed there was nothing wrong with the build, the issue was un-related.
It would be good to see the details posted since the reason I heard was unusual and an interesting warning about how small things can build up to a dead motor
Engineer report in:
results are:
bearing failure caused by overfueling/incomplete combustion + a restriction in the oil pickup which caused low oil flow at high RPM. the over fueling + the oil pickup restriction caused the motor to fail.
I'll post up the engineer report once ive edited out my details etc.
who tuned the new engine? As from what im reading there it has had problems since it was installed as the 8000klms travelled on an overfueled engine. This is critical on initial run-in as an excessively fueled engine will not allow rings to bed-in and the overfueled combustion chamber to release fuel mixture into sump area on compression stroke.
Edited by DiRTgarage
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
