  • Replies 56
Originally posted by Roy
...the R31 with GTR rims, looks tidy, any more pics.
that's my car mate. I aint got the link for pics here (not on my PC) so PM me if you want more. It's on of 800 GTS-R's ever made. And it goes alright.
Or if ya want, e-mail [email protected] i got a few more that aint on the net :D
But yer... Megz... those photo's have done the rounds now huh :D
that car and 6000RPM, you hit boost and just hang on.
RWD... light as, its really something to be in to understand
To give you an idea of the sillyness of this car before it's rebuild... in 3rd, sam mashed the pedal and in 2 secs this car produced enough smoke to fill the entire street with smoke.
That's how crazy the wheelsipn was and that was with semi comps on the rear of it when it hit boost, just two fat black lines down the road.
And i can vouch for sam's driving, after seeing 1st hand the way he controlled that can i can definately say that man can drive.
he still struggles with my clutch though :shake: :shake:
yeah te car is awsome on testing on the dyno 4 th ran out @ 280 kph :)we believe the car was used for wagan and for drag stuff if it hooks up 10 for sure.
it is the one car that has left a lasting impression.
do you why cause I could get used to driving it :D
yep niotto's and slick are on the card remember peeps this was only at 16 psi wait till it hits 28 psi or 2 bar :D
Originally posted by meggala
remember mario made well over 450 rwkw on stock internals tuning is the key
I was not implying anything megs. Just curious. Cant wait to see it run some numbers. I know tuning is a very important factor in the life of an engine. Good luck to everyone involved
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
