  • Replies 56
r u serious??? was this with no other changes??
so, 165rwkw on BMT's dyno would equate to how much on a dyno dynamics dyno (roughly)????
Originally posted by meggala
to give you an idea how conservative the dyno is a 180 with a big turbo made 165 rwkw on this dyno and went to the auto salon dyno and made 225rwkw.
cheers
sam, who actually owns the GTST? you or benny? or someone else?
it's a weapon... i remember seeing those two big bird shredders on it... there was an old guy with a nice R33 GTST with one of the 2835R's and he was running low 12's... that Endless weapon should nail 11's for sure in no time...
I might drop in tomorrow and check out ya new place, i have to go to Epping to have my exhaust changed so i can pass an EPA test :D so i'll swing past on the way back!
Andrew
huh! ...
nice to see my car has some attention ..
Gearbox? ... think it's a Trust Gearset but who knows .. has not broken so I expect it to be HKS or something known to be tougher (I hear trust box's are not da best in town).
Rebuilt with new piston, o ring block, and some interesting bmt headwork to get that RB flowing just nicely... tried the standard gasket to see exactly what would happen, now going tomei 1.5mill as it's a bubblin'.
Standard 2.6ltr size with fat sump, fat fuel pump, 1000 cc injectors and some solid tuning ... yes, it sure was achieved on BP Ultimate ... but pumped at Calder when I tested at the strip.
Yes, should be able to bust 10's :D ... tried to get that on my second run at calder but snapped the axle ... hope to crack below 11.5 next meet...
Please save the techincal questions for the good Doc or the boys at BMT ... all i do is finance and drive tha thing :) ... tough job i know ... what can i say? ... 2835R Powered RB26's and GTSt's were made for a reason - I'm not doing anything fancy here, just bringing them together :D
Cheers,
Oyabun
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
