not sure if this is the right place for this but anyways if its wrong correct me please
anyone has any nistune upgrade on a rb20det engine with stock internals. what extra have you done to gain like 300hp or so? intercooler, turbo, injectors, waste gate, fuel pump and .......... what next .
any one with this board and program no longer using and willing to sell me so i can feel that power?
https://www.sau.com.au/forums/topic/247493-nistune-board-on-my-rb20det/
put something in place of the cams plz dont want to add the pulling of the engine in the recipe
thats just wot im running to get that....
you get get same results minus cams with same setup just add more boost 2-3psi id say but pushing the turbo to its limits.. if not 2530 garrett 2871r - but it a bit more laggy but bit more power
not sure if this fit right here and makes sense
after removing rom chip from ecu and installing type 2 board etc. will the car be able to drive to the tuning shop or have i lost everthing pertaining to moving the car
can anyone give me a detailed description from start to be able tomove normally? even if i let a shop do this i like to know the pros and cons of this.
Sorry don't know how it works exactly, but in my case
Took out ECU and sent away
ECU came back with Nistune board and retained all maps which were in my stock ECU
Drove it for a week with no probs
Took it to tuner to tune :-)
INTRODUCTION
Base Image Programmer
All NIStune real-time boards require the “base image” to be programmed before they can be used. This is
normally done during manufacture – and cannot be changed by the end user.
Professional tuners who purchase multiple boards may find it necessary to change the base image, so we
have made the programmers available for this purpose.
JUST A LITTLE EXTRA READING
i thnk you should read this..... make life 1000 times easier.
http://www.nistune.com/documentation.html
awesome product, they also have the best aftersales and purchase / delivery times of any ecu dealer ANYWHERE.
yeah matt that little bit of info is coming straight from there thats why i said just a little extra reading
thanx
Not wrong there! I sent my ECU up on a thursday to my father in-law to remove my Mines Chip, we got it the Friday. Took the day to remove all the epoxy and still had to cut the chip out! Gave it to Pete (half of PLMS) who works on the desk next to him, Pete checked out the Mines map which was leaned out in the higher revs, speed cut removed and had 4deg of timing added across the whole map (yes that is all Mines did) then he fit the NIStune board and sent it all back to me very well packaged on the Tuesday. I got it on the Wednesday. Overnight delivery Via registered post from SA to VIC = AWESOME!
Get mine tuned on Friday at Status Tuning, can't wait. Have the cable and software on my spare laptop too, it's very cool stuff.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
