That first turbo you linked to is a variable geometry exhaust housing and will go anywhere from 5cm up to 22cm. It's LIGHT years ahead of anything garrett's putting out. Garrett with their "old tech" and all :laugh: As soon as somebody figures out how to make it work with the computer controller not integrated into the factory ECU of a dodge pick up, it'll be the best turbo out there. Imagine a 600rwhp turbo that spools 1.5 bar by 2000rpm.
That video was pretty interesting and it was cool seeing them blow those things up. Be ware of the copies.
  • Replies 198
I think the video is a bit of a crock. Im willing to bet some of the genuine turbos blow the same way. And a comp wheel blowing isnt going to go through the floor of the bus anyway.
Any way unfortunately the variable turbos at this stage cannot handle the exhaust temps that petrol produce. Although they may last a while on e85.
Yea, quite common to see these on newer diesel truck engines. clever setup but may be a while before they get tranferrred in to petrol engines. something to look forward too?
Yeah, I hope soon. There are a few people that are actually running them on gasoline engines with no ill effects so far (they are just manually opening and closing the variable a/r), but I'm waiting to see what the innards look like when the turbo comes off.
I was thinking of putting one of the 351ve's on the 30DET but it would not fit in the space I had for it in the low mount position. I would love to use one of these. they would not be hard to control. all you need to do is buy a digital fuel adjuster from jaycar, splice the output from your AFM into the ecu as normal and run the other feed to the adjuster. the output from the adjuster is completly programmable. and will output from 0 to 5v or 0 to 12v. this then goes to the actuator and presto! completly programmable vairable geo turbo!!
you would have to spend quite a bit of time on the dyno to tune it though.
the other way to do it would be via injector duty cycle. but airflow would be the better but harder way about it.
I also looked at using a map sensor
There's a reason that the 911 Turbo costs 300k
It cost around that much before it had variable vane turbos on there, but I know what you mean. Imagine buying one through Porsche!
Another thing to note they are only tested as far as Porsche's R&D goes. Which is not to say it is inadequate but it is still new tech. in relation to petrol turbos.
CEF, I think the control unit is a digital kinda thing, not analog 0-5v or 0-12v; unless you are talking about hooking it up the the motor directly. I don't know much about those things. Can you send me a link to the jaycar thing your talking about? I've never heard of jaycar--I'm assuming it's an aussie thing?
Also, how much boost have you made it up to so far?
the jaycar thingie is an analog voltage bender much like a safc. it comes in kit form and costs about 80aud. hmmm the ones i was looking at used a variable voltage input to change the a/r in a linear fasion. i guess i would have to buy one to find out.
so far on mine i have not upped the boost yet, its only running 14psi at the moment. i will have to wait till i get get some dyno time to tune it properly. even at 14psi its to dangerous to look at the boost guage to see if boost is steady to redline. will have to wait till I get it on the dyno to find out. even then for the longevety of the motor i am going to cap power at 300rwkw so i will not see over 20psi.
I might upp it a bit on the dyno to see what it will do but i really dont want to lunch the motor for the sake of a few figures :down:
cheers
I've been studying these Holset turbo's for countless hours, finding compressor maps on these is so damn hard.
The problem I'm having is that the engine I want a 600-700HP turbo for is my VH45, looking at many of the holset compressor maps they don't have the width at the bottom of the map to do what I want, but look to be awesome for high boost. I need 60lb/min @ a pressure ratio of around 1.7 the turbo's that seem to fit are
HX40 B8574M just on the 60%@60lb choke line @PR of 1.7
HX40 B8584M inside 65%@60lb/min @PR of 1.7
H1E 8284AD inside 65%@60lb/[email protected]
H2C 8625N almost 70%@60lb/[email protected]
H2E 9551BA inside 70%@60lb/[email protected] but it comes on at 35lb/min which seems very late, I've calculated around 18lb/min @3500rpm
I've posted the above for reference if anyone is searching as there really isn't that much info for holsets on larger petrol engines.
Does anyone know any more info about the turbo's I have posted, particularly how many blades they have on the compressor. There are so many 8 blade holsets around but no 8 blade holset I have found will flow the number I need at low boost.
Falc, I had a look at the compressor maps when i was choosing a turbo for mine and had difficulty getting the correct compressor map for the turbo I was looking at so in the end i just looked at the power it was making at what boost on as many cars as possible.
I came across the map that is for my compressor after I pulled the turbo apart and infact the compressor is rated to flow an incredible amount. on my setup at 20psi it will flow just a shade under 47lb/min at full noise. at 3500 rpm it will flow 22lb/min. and that's only 220odd hp.
I might have got my volumetric efficiency wrong and therefore my calc's could be wrong. any once you put the compressor in a cover and bolt a turbine in a restrictive side all the maths go out the window. I am guessing that the 12cm^ or even the 10cm^ @20 psi with these turbines will still flow enough for 350rwkw. I am basing this on the fact that a .63 rear can flow 300rwkw and the 10 and 12cm considerably bigger.
so the HX35 looks like it will flow 47lb/min. @20psi. that's 350kw. the 10cm^ housing looks like it will also cope with this power level and the standard RB manifold will start to choke at 300rwkw and that would be approx 330 to 340 flywheel kw?
so in theory the HX35 looks to be the perfect turbo for us.
I have included the map for mine with a line at approx 20psi.
Jaycar also do a kit called Intelligent Boost Controller and it can be referenced off an airflow meter signal from memory . I think SK built one some time back to get better boost response in a Stagea .
Just on the VTN/VATN thing , don't forget this is Variable Area Turbine NOZZLE - not variable area radius ratio (A/R)turbine housing .
There are a few ways to "throttle" the exhaust gas speed through the nozzle and into the turbine blades .
You could also argue that they are a variable turbine inlet pressure ratio housing .
I believe VATN controllers are quite involved to set up because accelerating the compressor and getting boost at the wrong times can lead to surge and detonation issues so not quite as easy as the usual bypass waste gate system .
You mainly see these on dieseasels because they generally have lower EGT than petrol engines so the device used to vary the area of the turbine housings nozzle doesn't have to cope with as much heat (cheaper material spec parts) .
If you don't mind using bush bearing turbos Garrett also do GT wheel spec plain bearing units for diesels so it doesn't all begin and end with museum pieces like crude old T04B/E/S/R units .
I've been wondering for some time now why someone hasn't tried using a Garrett GT4082 turbocharger .
These use a 77mm 73 trim GT40 turbine in a T4 flanged I think 0.94 A/R TS T4 flanged turbine housing . The compressor is an 82mm GT40 which is the same family as the compressor in a ball bearing GT3582R only in 50 rather than 56 trim . The comp housing is from memory a 0.58 A/R GT40 port shrouded thing and from pics I've seen isn't much if any bulkier than the GT3582R's T04S housing . Giz a sec and I'll look for the link .
Best I can do cheers A .
http://www.extremeturbosystems.com/product...roducts_id=1421
Edited by discopotato03
doesn't really help me though because high airflow at high boost doesn't suit my engine. Everyone seems to be putting these on smaller engines and making a lot of power at a lot of boost, most of the holsets will choke on my engine before making the same power. I need around 10psi at the manifold to make 600hp. I don't want more power because I'm running an OS giken twin plate through a Z32 trans and R200 rear end, really not a fan of blowing drivelines
Whats the biggest petrol engines you guys have seen single holsets put onto? any 1UZ's? what were the results?
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
