  • Replies 719
The PRO class list has not changed in a while, but the others are growing every week
Not sure why it would say updated 9th Jan 09.
Give Nathan from Superlap a call or send him an email if you are keen.
I have just entered another car, so it is not full yet.
Edited by Bozman1
Cool. I've just entered now. See how we go...
i didnt realise the lotus your running is Jason Micaliffs. Was speaking to him yesterday afternoon and he was saying your good for at least a second a lap. Your a bit special Boz. Then i gave it to him a bit for not driving his own car lol. but its a serious event now and very competative.
Tested the Pulse Racing Subaru that I will be running in Open yesterday. A pretty fast thing indeed :D
Yep the Lotii's are not running in PRO.....written off, not ready etc etc
You people are all so well informed in this little world.
Yes one lotus, the yellow one, was written off.
The other one, the blue one, which did 1:12.0 last year to set FTD, yet somehow had the time voided after some whinging by other teams...... blah blah
.. the blue one was NEVER entered. Been there done that. For some reason we were put on the entry list. Not our doing. Perhaps the organisers wanted some variety??
We are sticking to production sports racing. Too much $ being thrown around on hand-grenade enigines here for us. You would be shocked of you actually compared the cost (both purchase and running) of our Lotus with these datsuns. our car is set up to run flat stick for 1-hour races, our engine is stock 9apart from the blower!), from a front-cut integra, and un-touched after two years of racing.
All the anti-lotus talk is interesting. Given that both the cars from last year were road registered and used wrecker engines, it's quite laughable to say it's unfair that 700hp GTR's shouldn't have to compete with 4-pot 2 litre tupperware containers on wheels.........
I wish you all well at Superlap. have fun.
Edited by pwr
OK :P
im not sure if its Skylines or Skyline owners that you havent got much time for, but im shore that in any class of racing someone is going to whinge about something....You can see why the GTR boys would be upset though, 1200hp 4WD, definately behind the eight ball.
those "cars with wrecker engines" as you call them still cost more than most of the datsuns so shut it with the trying to down play the obvious advantage of a race bred chassis with masive power upgrades and the overall weight of a fart in a bottle.
These datsuns all run datsun engines too. Trot ya gutless lotus out with its original engine intact and see how it fares against the dattos. Meanwhile, find the tissue box.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
