How do I quieten my stock blow off valve without putting my air box back in? I have a FMIC and the box doesn't fit anymore because of the cooler piping :D
I took my car to the licensing centre to get my yellow off but they said I have to quieten the bov somehow, and then they'll give me a permit for my cooler and my pod filter :confused:
I admit it's pretty loud, but it's totally stock!
What can I do!
Cheers :)
https://www.sau.com.au/forums/topic/24809-stock-bov-yellow-sticker/
JiMiH my stocker bov was f'in loud when i had to get mine registered, they couldnt say a thing though because the compliance engineer had passed the air filter I had and therefore theres no possible way to shut the damn thing up!
I hate the sound of the standard one, its so bloody loud its not funny.
R33's must have the recirc pipe further down the line. I think the problem on the R32 occurs because the recirc pipe joins right before the air filter.
Just take the standard one off and bolt a plate over the hole, its not illegal NOT to have a bov now is it! Just get the yellow off and put the bov back on.
Red17
Cheers for the replies guys :)
That's a good idea about putting a plate over the whole thing i might just do that .... failing that I'll be up to your house Steve :)
I went to the Welshpool pits (they also didn't pass me because I have a chrome-look cup on my boost guage :) )
Originally posted by JiMiH
(they also didn't pass me because I have a chrome-look cup on my boost guage :wave: )
How do you put up with that shit?!!?
I admit, I haven`t been in Oz for quite a while, but that is just freekin crazy! On what grounds would they not pass you for chrome on a boost guage? Did I just type that...? *chrome on a boost guage*... yes I did...:confused:
The reason for pillar mounted guages being a problem is if they are within a certain radius of your head (can't remember number)and could be struck by it in an accident. Vision wise, as they are off to the side I don't believe they are a problem.
  • 3 weeks later...
i have Blitz BOV on my car and i have it permitted as well as my Filter and FMIC. on my permit sayd BOV not to be too loud hahah thast the funniest shit i have ever heard coz it is loud as f@#k. I went to welshpool. They didnt pass my pillar guage coz yes was chrome and the light reflection was the only problem. I taped it up with tape and toook it back over (they passd it) its all a crock of BS if you ask me. My car handles and stops better than most cars out there yet i still get yellows for mods even if they are improvements. But what can you do. Cops should learn a little about cars and mods b4 they go out in the world and tell us what is and isnt wrong.
With little choice, its a police state here, ironically, they'll sticker a jap import for stupid reasons, yet a smokeing POS with bald tyres and rust throughout will drive on by and not get a second look
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
