  • Replies 108
Posted Images
R.I.P not good at all prayers go out to his family and loved ones must be very hard for them.
Ps: looking at the car really close you can see two door handles have a realllllly good look i think your right might be a 4 door
bugger
heaps sad aye
So was he from Beechboro...or Ballajura? I'm freakin out here aye.... I'm from Beechboro and went to school in Ballajura... I'm so worried it's someone I know
I wonder how long till we find out, will they release a name, do you think?
Edited by MeLSki
There's also that Sam guy, hasa silver + black bonnet.... but dunno if its 4 door or not or where he's from/age etc
Edit *** it's ok
sam5709(aka SLOWPOK3) Last Seen: Today, 01:25 AM ;)
Edited by MeLSki
Can you scan the article and post it up? Anyone?
The only silver 33 with black bonnet I can think of is alpinestars(andrew?) but I think he's done a 34 front end and doesnt have the black bonnet anymore.. plus it's probably off the road?
can confirm it is not andrew; his car has r34 front and is not rego.
No, Vincents from SoR, plus he has rims, the car is silver with grey bttom half and black roof.
One of by colleages's daughter was there, apparently someone walked in front of the Skyline, ad he swerved to miss them. Such a waste of a life. I hope the 6 other people are all ok.
Apparently the 6 other people are ok, just injured.
Someone walked out in front of him? I heard it got airborne? So he swerved..into oncoming traffic?? The papers won't say he swerved to avoid a collision with a pedestrian....they'll say he's hooning...so sh!t
That is all messed up dam sad ;)
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
