I need a mule for a few days. I have developed a drive by wire cruise for the sedans and coupes with the VQ35DE and I want to do one for the VQ25DET.
I'll need the car for at least 3 days. i need to map out a few things on this engine that I believe are different to the VQ35. cruise control takes the place of the blank spot on your steering wheel (note I need the car to have a stock wheel..) and behaves as teh stock system should. if you want the cruise system on it I'll leave it there for a discounted fee
PM or reply here if you can help.
https://www.sau.com.au/forums/topic/249034-attn-brisbane-m35-owners/
Hey Chris,
When do you need the car? Mine will be free after the new years.
And How much discount??? :(
after the 5th of jan or there abouts. discount can be discussed after I map the car - not before :)
Quoting Sid From Ice Age: "You are a very shrewd mammal" :(
As long as Craig delivers my wife's V35 in time my you can have my car for testing.
I have a mule - ta!
Ziel20l ,
its a professional fitted kit only - NOT and I repeat NOT a DIY kit. there are too many variables to make it a DIY option. safety being one of them.
  • 3 weeks later...
  • 2 months later...
my mule has arrived. testing begins in the morn. :)
hey Chris, i was wondering how you are progressing with the cruise control for the m35?.I for one am very interested,regards graham.(i,m on the Sunshine Coast with a 2002 vstagea.)
  • 3 weeks later...
Chris,
This may be on my list of things to do in the future as I think I will be doing quiet a lot of freeway driving.
How do I go about getting a kit ordered when I want to get it fitted?
Thanks
Hi Chris,
Would be interested as well. Is it using the OEM steering wheel controls, or are there some other options. Car I am buying at has a Momo wheel and I think does not fit the OEM controls...
Also, how much do you think the kit would be?
Thanks.
Chris,
Thanks
when you are ready email me , I'll invoice it out and send it to a shop in condell park to be fitted. fairly easy.
Hi Chris,
Thanks.
nope needs the OE wheel as the controls are OE. price I would rather keep off the public side of things. I hate shitfights and this is one way of stating one. send me a PM and I'll tell you.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
