  • Replies 99
what exhaust housing did you pick and why?
I didnt realise that this was an interview... I will post the turbo specs soon.
Bump also wondering if your using the stock exhaust manifold?
Yes I am using the standard manifold.
What star sign are you?
Do you like long walks on the beach and candle lit dinners?
Do you make love on a bed of frangipanis?
  • 1 month later...
Update:
Parts have arrived and I have spent quite a few days in the garage putting them all in :)
I love reading this on the side of the box (usually means there is something nice and shiny inside).
Mmmm Trust front pipe... And split dump. :P
Exedy Hyper single ceramic button... (flywheel machined too).
Genuine Nissan water pump (had too many problems in the past with inferior water pumps).
Gearbox and tailshaft ready to go back in... (Note the "custom" crossmember).
Front of the motor - Naked! :)
New water pump installed.
Wastegate actuator mount and connector pin had to be modified to get them into the right position.
All parts now installed, the next step is to make up a custom intake pipe for the turbo, replace all oils and fluids and then a dyno tune!
More pics to come (sorry Michele, still no Frangipani stickers) :P
Stay tuned.
Im hoping to have it running in the next 2 weeks, but it wont be driving on the road until its tuned and I have had a few other "goodies" installed :P
It should all be finished by the end of this month... Fingers crossed :P
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
    • Yep four point harness. Mounted to a bolted in brace running behind the seats. Dont use it for daily driving tbh but good to have for when its needed plus it looks cool.
    • I had to double check the thread title r34 gtt offset advice lol. Thought maybe i posted on the wrong thread. 😂
