  • Replies 40
some good points here guys...thanks
im gona definetly get my bro in-law to drive it while i drive my mums camry, it'l be interestin to hear it from outside and wot other ppl can hear, when both opening it up and just crusing...
if stil not happy out goes the muffler in goes the 3" pipe in its position....
Mine got a lot louder when i got rid of the stock turbo.
Then when i had the HKS cams it got ridicolous, when a cop pulled me up after i got them he said "she's a bit loud aint she?" i was like "yeah she's a bit angry" and he just noded and let me go lol. First good cop ever.
Point of the story, get rid of the stock turbo and get some cams lol.
cams on a 1600 made it go from meh to headache inducing. I think the stag sounds shit in it, but if i rev it standing outside it sounds farken sweet, and neighbours mentioned when they have heard it how good it sounds at WOT
ive got a 3 inch turbo back system from jjr with a metalcat cat converter, Sounds sweet to me, loud but not unbearably so. Sounds menacing at low revs and turns into a really angry bark higher in the revs. Would be the way to go if you have a tight budget in mind.
I had an exhaust place make me a 3" mandrel system with two magnaflow straight thru mufflers. standard cat
then i had it ceramic coated.
really quiet. I flew past a mate on the way home from work the other day. He said all he could hear was turbo whistle...
I have aftermarket manifold standard turbo and aftermarket dump pipe.
I had the mufflers fitted with bolt flanges so i can just pull them out and fit straight pipe easy.
Cams make a HUGE difference to the sound.
Even with stock cams and adjustable cam gears you can get a noticeable change. Pulling 2-3 degrees out of the exhaust cam on my set up would make the difference between pass and fail noise emissions....The bigger your exhaust is, the more cams will change the note...
i think you need to let someone else drive your car so you can hear it from the oustide, because your used to your car you cannot really hear the toughness or notice it.
This happened to me, got a few videos and then realised damn she does sound tough as!
Try it
this is so true.
i used to hear them drive past me n think fk that sounds tough
until my mate drove my car for me and i realised mine sounded even crazier. i'm not sure why its hard to notice the RB growl when your inside the car probably because the exhaust is behind you facing outward.
do what my mate done best sounding car its an s13 with an rb20
hes just got dump to decat pipe to nothing (yep he just took it all off) - little scary following him and seeing massive flames coming from underneath the car just infront of the fuel tank
my mate had a high mount t04e on a stainless mani and and external venting. he also had a cat. 3inch off the turbo with a 5inch tip. That thing sounded sooooo angry even on idle. When the external opened up, it scared every other pedestrian and driver on the road haha. sounded Better then a V8.
When he got rid of the cat, it was even louder. scary. i remember i was sittin in the passengers and he started it up and it kinda felt like my head was vibrating..
Personally, too me a car that is just ridiculously loud pushing 120db doesn't do it for me. (referencing to some people talking about no cats/mufflers/straight pipes etc). I prefer a car that has a nice deep tough note. I've heard plenty of RB's, SR's, V8's etc that sound like a banshee screaming its head off, but sound absolutely horrible. Ever heard a SR with no exhaust........no thanks.
Just my choice though.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
