Nissan Skyline R33 GTST Type M, 1995 Model. Black in color with all the usual stuff like power windows/mirrors, climate control etc.. Bought the car basically standard 6 years ago, since then have spent over $50k on modifications. The majority of parts have been fitted to the car around 15,000kms ago and were bought new. Car is serviced every 5000kms, always high quality and genuine parts used. The car makes 307rwkw on 17psi on a conservative tune, setup is good for around 400rwkw mark. With the previous setup on this car it ran 12.3 quarter mile times with 260rwkw. Engine has been compression tested and everything is fine. Was tuned by Croydon Racing. The engine bay has had a lot of detail put into it, all that remains is a re-spray to freshen up the car and it will be like new.
Exterior/Suspension
- sprayed and detailed brake calipers (red with white Nissan logo)
- GTR front bar
- Original GTR grill
- R34 GTR rims
- Xenon headlights
- Clear side indicators
- Tein super street damper fully adjustable coilovers
- Whiteline heavy duty sway bars front and back
- Whiteline caster kit/suspension bushes
Interior
- Front strut brace
- Rear GTR strut brace
- Complete R33 GTR interior (seats/door trims)
- Nismo heavy duty clutch pedal bracket
- New battery
- Apexi RSM with stand
- Apexi EL2 boost gauge
- Blitz SBC-iD electronic boost controller
- Nismo white face speedo (320km/h)
- HKS type 1 turbo timer
- Nismo gear knob
- Short shifting kit
- Pioneer mp3 head unit
- Hertz rear speakers
- Pioneer 2 way fronts
- Genuine Nissan mats (full set)
- Chrome door sills
Engine/Performance
- Full engine rebuild at 94,000kms, including full balance and blue printing. Cost me just over $6000.
- Garrett GT3540R turbo with 0.82 rear housing rated at 700hp. Fitted with speedflow braided lines and fittings, turbo cover has been polished
- Tial 38mm wastegate
- Tomei 256’ cams (exhaust and inlet)
- Tomei cam gears
- Custom 6Boost exhaust manifold with temperature coating
- New custom dump pipe and screamer pipe fabricated
- High flow cat
- 6Boost turbo heat shield (polished)
- Micks metal craft aluminium intercooler with custom fabricated piping
- Oil cooler with braided lines and speedflow fittings (mounted behind front bar)
- Turbosmart Blow Off Valve which also sits behind the front bar
- Apexi pod filter
- Radiator air guide
- Nismo 870cc injectors
- Bosch 044 fuel pump (in boot)
- Sard fuel pressure reg
- Custom surge tank receiving fuel from standard pump
- Oil catch can with K&N filter/breather
- (ALL OF THE ABOVE FITTED WITH SPEEDFLOW FITTINGS AND BRAIDED LINES)
- Z32 afm with tomei plug
- Splitfire coil packs
- NGK spark plugs
- Greddy plenum (polished)
- Aluminium radiator
- Nismo radiator cap
- Nismo oil cap
- 3.5 inch exhaust from turbo
- OS Giken twin plate clutch and flywheel kit (OSD2C)
https://www.sau.com.au/forums/topic/249513-310rwkw-r33-gtst/
thanks roy, have had the car for quite a while and have though of selling afew times. Just keep pouring so much money into it. all it needs is a respray and the thing will be like new!
Christmas bump!!
Lepperfish
yeah the engine was rebuilt using standard internals. The reason for this is that when i was doing the rebuild parts for the car were not as easily to get as they are now. I was dicked around by wiseco for over 3 months during which the car sat in the garage waiting, so i decided to just got standard items.
Man thats a bargain.. I thought you sold this car already!!
I have personally sat in this car and its deff worth the price for all the mods you get with it!! Wish you the best of luck selling it!!
Edited by siddr20
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
