hey guys !!!!
got a hi-flowed turbo and all supporting mods on my r33 s-II (coil packs, fmic,z32 afm, pod etc.).
the turbo can't flow enough air at high rpm so it drops from 18psi to 15psi and making only 301rwhp.
any ideas/ suggestions on what my options are to get to 350hp mark ?????
Will I have to get a new turbo altogether or are there any other options???
If new bigger turbo is the only answer, what turbo? are there any bolt on solutions?
here's the dyno graph ..
Cheers !!
https://www.sau.com.au/forums/topic/249701-im-after-350rwhp/
How big is the front, if the front is big enough maybe its just the rear housing that is not flowing enough, in that case the simple option is a vg30 rear housing which is .8 not .6 like and rb25 turbo, i have a high flow with one, only have fmic, k&n panel filter, 3" exhaust, hi flow cat and one piece split dump and it makes 299 rwhp, once i put in bigger injectors, z32, fule pump and management i will be maxing it out at around 350 rwhp.
My dyno graph is much the same as yours but i am making the same power as you at the same rpm but with less boost, my 299hp was at 6000rpm @ 14psi.
what wastegate actuator are you using? if you have a rb25 one then they are weak as piss and can cause this.
get a upgraded wastegate actuator with a 15psi spring and then re-tune it to 20psi and you should get close to the power your after
Thanks for the replies guys, I'll check with the guy who hi-flod the turbo, what housing .6 or .8 and what wastegate actuator were used. At this stageall I know is the wastegate is internal...
checked with the workshop and it was the stock rb25 wastegate actuator used (3 psi or something). will change this to a better one in Jan... he said this will be a 13.8psi... will this do the trick??? I guess only one way to find out !!!
  • 3 weeks later...
Just wondering if setting the higher boost duty circle will help holding the boost?? :D
Can anyone confirm the size of the stock wastegate actuator? I thought it was 7psi?? Cause i think they did the same with my gt3076r upgrade. Its a lag fest. I got a 18psi spring going on next tuesday.
In your case there is no way you will make 350rwhp with a high flow. I bet Andrew told you that you wouldnt see those figures too. Thats why i went the gt3076r and not a highflow.
However i reckon you might get 325rwhp at most on his dyno with a 1 bar actuator. The boost will come on heaps early and should hold all the way.
um, rb25 actuators are 7psi, rb20 actuators are 10psi, HKS actuators are adjustable but from memory the minimum is 14psi? correct me if im wrong,
thats why people say using the rb20 actuator on the 25 turbo ends up working better,
HKS actuators cost mmm well with our crap exchange rate now probably $200, was $130 delivered when i checked last before the crap dollar
I kinda realised that I'm not gonna get 350hp with this turbo, but if I can run 17-18psi and hold through out the rev range I'll be more than happy (with what ever the rwhp number I get)
I don't wanna pay for whole new turbo setup just for few hp
Is it straight forward to change the actuator to a 1 bar actuator? which brand is recomended??? are there 18 psi actuators out there?
and yeah !!! Andrew told me that 350 is not gonna happen with this turbo. :D
Just get the HKS actuator. My stock actuator got busted, stuck at 0.4bar all the time. Got the adjustable and wind it up til 0.73bar which was max for the stock turbo (using stock ecu). Winding it up anymore would cause like hitting a wall kinda feeling. lol
BTW the HKS acutator can go over 1 bar easily.
Edited by teng
and yeah !!! Andrew told me that 350 is not gonna happen with this turbo. :P
Well if you hadnt noticed your thread says im after 350rwhp. Your asking the wrong questions.
Get a suitable turbo first!
Do people know how much you can get out of a high flowed r33 turbo? Mines a RB25 and im making 290Hp at 12psi. But they guy that tunes it said he wound the boost up too 20psi but only got about 10 more Hp. Does this sound right?
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
