So I'm going to get a i7 2600k along with a Z68 mobo of some kind just wondering what is a good aftermarket cooler for it?
I currently have a Zalman for my Q6600, seem to work fine.
Also what is currently the best bang for buck SSD out? Looking at the $250 - $350 mark. Only need 60Gb or so as it is only to be a OS drive. I'm getting a 600GB raptor for my games & all my old HDDs will carry over as storage drives.
My current gen 1 SSD is starting to die I think (randomly windows will freeze up & upon reboot, windows disk checker will pick up & fix some random corrupted files on the main OS drive).
Yeah coolermaster 212+ are good value for money I hear.
I got a Gigabyte Z68X-UD3R-B3 mobo. It's comes without a display port which saves a little money, meaning you must own a dedicated graphics card.. If you're buying a 2600k though I'm guessing you're not going to use the integrated graphics ;)
It does however still have the 'old school' style BIOS, not one of the fancy new GUI BIOS's. Whether that matters is personal choice, it will get updated eventually anyways.
@ SoFreshSoClean you've never done super pi test on your current rig?
this image shows intel gfx
the MA motherboard has a display port(sorry its HDMI) also i think main difference would be the amount of usable PCIe slots and you have pci to which i cant use my PCI tv tuner i had to rip out the pcie one from the media center, i too was expecting the newer fancy bios but that's ok touch bios works fine too
thats where the extra money from a 2500k to a 2600k is
still a good score but not quite as fast, are you still running 4.3ghz
Yeah still on 4.2.. ordered the mounting bracket so I can put on my Thermalright Ultra 120 today :)
I got 5475 in 3dmark 11 on performance mode.. have you run that?
yeah, thats a good result what gfx card
i managed, my gfx card is very hard to overclock it gets unstable very quickly
P5440 3DMarks i7 2600k @ 4.3ghz @ 1.32v gfx 6950 @ 880mhz
http://3dmark.com/3dm11/1629327
im thinking of rerunning it with the suggested drivers
not sure if turning of HT and running it on 1 core would make a difference
AMD 6950 @ 880mhz (BUT it's unlocked to a 6970, makes a bees dick of a difference though anyway)
I can't actually record my result on the 3dmark leaderboard because of what I've done to the graphics card, says its unsupported or something
oh you have the 2gb model thats cool that our systems are sooo close yet dont seem to make a difference
yeah mine isn't recorded either
Your result has the following problem(s) and will not be shown for example on leaderboards:: Graphics driver is not approved. (What is this?)
and also this msg
Your Score is Low Compared to Similar Systems.
There may be a problem.
nice to know it thinks there may be a problem, or others have hacked their scores ;)
Wouldn't surprise me.. I got that msg too, I was thinking WTF both my CPU and GFX card are overlocked heh.
That's what I was saying before the multi threading doesn't really make a difference in games, if you do video editing it will power through it though!
if you have a Z68 board you can use the integrated GFX + Quick Sync, think it is limited to a particular program or something for encoding.
http://3dmark.com/3dm11/805476?show_ads=true&page=%2F3dm11%2F805476%3Fkey%3Dwf5kxcDcHeZrKCn4rTeQkPycqmLbBh
P6383, physics test really boned me, think it would go up a fair bit when I get around to fitting an aftermarket cooler and cranking it up some!
wow help me figure this out
you have 2x gfx card with physic processor on board and only scored Physics Score 5609
and i have 1x ATi no physics and scored Physics Score 9245
i know it accounts for little but scored over 400 in the CSS stress test
oh our >>comparison results<<
it was a while ago; could give it a go again with updated drivers, but AFAIK, the physics test, at least in the demo version is a CPU test, not PhysX. Would explain the huge discrepancy between the score you got and the score I got.
Wow, I gotta get me a second GFX card :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
