i did a search and went back to about mid 07 and thought no point going further back due to development. or i typed the wrong shit in.
any ways i have an rb25det s1 pulled down and it will be rebuilt with pistons and rods, bearings, studs, gaskets of major brands. the motor will see drift work plus track/grip. is there anything i should spend my money on to avoid say oil problems or somthing simialr which is easy to fix but can cause big problems if i dont.
any help you can give would be great.
cheers, steve.
https://www.sau.com.au/forums/topic/249968-comman-problems-with-rb25det/
there is a massive thread based on the oiling problems that plague the RB25.
I'd find it and do everything that it suggests, because most of the problems arise when doing track work, in high revs.
Dry sump will fix everything :P
But upgrade the oil pump
Good catch can and breather setup
Maybe head to sump oil drain
500mls extra oil.
dude, putting a bigger oil pump on, and not doing the rear head drain, or blocking the rear oil feed in the head makes the problem worse.
The whole problem is oil pooling in the head do to bad drainage at high RPM. If you put a bigger oil pump on, it will simply pump more up there and into the catch can, creating a disaster. I've seen this happen - GTR oil pump on a RB25 with no extra drains... or the rear feed blocked. Blew most of the oil into the catch can.. and then when the sump was starved... bang.
You're giving bad advice I'm afraid...
Edited by The Mafia
The advice I've been given by most engine builders is not to restrict the oil getting up top. It's all in freeing up getting it back down to the sump.
IE, you REALLY want a good drain setup to get it out of the head. Then, you're all sweet.
The issue is only at high RPM, so who knows what it's doing when you're blocking an oil feed off and sticking to low RPMs. You might be starving the head of oil slightly.
I did see a drain set-up for RB30 heads on ebay, was simply a fitting tapped into the rear of the head for extra drainage. Would thios also work on an RB25?
I'm just using the fitting that TUF_RX3 from here made, which is press fitting into the back of the head.
Others drill and tap a fitting in.
Well, the GTR have a blocked feed from the factory, and a restricted feed up the front. So less again.
I'm pretty sure SK has said that even with a blocked feed at the back, there is still more than enough oil for the hydraulic lifters in the RB25.
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
    • Welcome.  Here's what I have noticed about forum vs FB..... FB; seems to be wallet racing, and the same few questions asked over and over. There *may* be some groups that are closer knit, but most have changed for the worse. SAU; unfortunately, no longer in its glory days. But....genuine people with similar interests. Not all about how much you spent and saying you dont have enough power. Sooooooo much knowledge available. Have personally seen people post up about literally topics I made myself, asking on FB like no one has done it before. Most has been done, and most of that is here.   If you ever feel like just general chatting theres the wasteland.  Other interests are also generally covered in other areas of the forum. Hope you enjoy hanging around. We would love to have you.   P.s. nice 32 馃榾
    • Nah, natural progression is euro. Because, we're all gluttons for punishment. And, what's more punishing than euro?
    • That's Garrets way of saying it will manage boost itself. Give the wastegate no boost reference...
