  • Replies 2.5k
Posted Images
Yeah if he really said that (and it wasnt altered by the media etc) then i think its time he went to a nursing home.
I wish flavio was running the show. Or someone who likewise cares more about F1 Racing than F1 Money :banana:
Looks like the weather should be ok
ill lock it in now
the diffuser-gate saga will end up being ruled an illegal device, im sure of it
fcuks sake we havent even started yet and the first 'gate' is well under way
what's the 'loop-hole' in the rules that makes the diffusers of these teams slightly dodgy?
Grrrr need to setup HD on my LCD.
Reckon its a wise idea to mount a antenna on the roof in this weather ??
For the F1 i think its well worth it, ill take my chances hehehehe
I vote for todt or flavio
would really make it about the racing more than politics
Phark commercial digital tellie. What is that? We don't get any at all where I am. Never mind HD.
Here is a rough explanation of what Williams & Toyota have done with the diffuser/crash structure .
http://www.formula1.com/news/technical/2009/0/623.html
http://www.formula1.com/news/technical/2009/0/622.html
Coverage starts at 12 in Sydney.
I don't think you need to go out on the roof with digital signal it's all or nothing
You either have signal or non at all a simple butterfly antenna will do
Yeh i need to actually put a outdoor antenna on my roof, because the tv isnt hooked up to one in my games room
just hope it doesnt rain lollll
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
