  • Replies 2.5k
Posted Images
You get the one-eyed cocks that understand zilch about F1, but follow Ferrari because they are either stupid wogs that don't know better or can't be rooted supporting anyone else. There are those that have a vauge understanding of F1 history, that begins in roughly 2000, never bothering to look back past beyond the Schumacher years, many wouldn't have the first clue that he also drove for Benneton or Jordan. Some that are very knowledgable about F1, but like the Collingwood supporter, will always hiss and cruse when the FIA go against them (Which is rare these days) and bag everyone else for being either crap, cheaters or just plain incompetant.
In all honesty what hope have they got when, for example, a certain multiple championship winning Ferrari driver (hint it was Michael Schumacher) in all seriousness once asked whether him & Irvine locking out the front row of the grid was the first time it ever happened for Ferrari?
It always used to sh1t me to hear Murray Walker banging on about how everyone in the race did such a wonderful job. But the longer I follow the sport the more I realise he had a point.
Anyway Ferrari aren't going anywhere. Nor, as far as I know, are anyone else.
Maybe a bit like the revolution is just a t-shirt away, P1 is about an hour away?
Very interesting practice session, both Ferrari's in the top 5..... Vettel faster than Webber and wtf, Piquet went faster than Alonso!!
Truth will be told however in qualifying later tonight where no one can hide from the scales.... :D
Edited by TALBO
Well he has the opportunity to still get points, just have to hope that he shows the same agressive overtaking he demonstrated in Malaysia. Q3 looks interesting.
Oh yeh...and FAARK SUTIL! That hack couldnt stop spinning last weekend, he binned it when he found himself in the position of having made less mistakes then all the other people in the midfield who had tripped over one another....and now not happy enough with writing his own race weekend off with binning it wants to baulk cars on quali laps!! FARK!
But why is it Mark didnt even get a banker lap in to ensure Q2... Mark makes his life difficult at times
I just saw the qualifying results and was wondering wtf happened to webber. That's pretty much farked up the race then hasn't it lol.
Go vettel now I guess. As long as Hamilton or Alonso don't win I'll be happy :/
Vettel looks like he is on track for another win. Hamilton might get off the line quite well and he is a genuine chance with KERS of grabbing a spot or two from the start.
1. Jarno Trulli, Toyota, 648.5 kg
2. Timo Glock, Toyota, 643
3. Sebastian Vettel, Red Bull, 659
4. Jenson Button, Brawn GP, 652.5
5. Lewis Hamilton, McLaren, 652.5
6. Rubens Barrichello, Brawn GP, 649
7. Fernando Alonso, Renault, 650.5
8. Felipe Massa, Ferrari, 664.5
9. Nico Rosberg, Williams, 670.5
10. Kimi Raikkonen, Ferrari, 671.5
11. Heikki Kovalainen, McLaren, 678.5
12. Kazuki Nakajima, Williams, 680.9
13. Robert Kubica, BMW Sauber, 698.6
14. Nick Heidfeld, BMW Sauber, 696.3
15. Nelson Piquet, Renault, 677.6
16. Sebastien Buemi, Toro Rosso, 678.5
17. Giancarlo Fisichella, Force India, 652
18. Mark Webber, Red Bull, 656
19. Adrian Sutil, Force India, 679
20. Sebastien Bourdais, Toro Rosso, 667.5
Edited by wolverine
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
