  • Replies 2.5k
Posted Images
are you not contradicting yourself? the fact that a four stroke engine is being turned in excess of 20000rpm is unbelievable, how is that not the pinicle of motorsport? the absolute limit of technological engineering? giving teams this freedom doesnt mean they will all take it. Unreliabel cars dont win championships.
Can't wait to see 20,000+rpm though...
However I agree with Montezemolo, F1 is ment to be the pinnacle of technological and engineering in motorsport, the absolute limit of racing... I think this approach is killing that..
All I'm going to say is that although F1 remains cutting edge and very advanced in a technology and engineering sense... It is also rapidly becoming the pinnacle of gheyness too, with Max and Bernie and some nazi sl*ts all parading on the first ghey and formula 1 mardi gras float!
So we can only imagine what they would've been capable of had they not freezed development
I'm hoping Ferrari's new aero package works for them this weekend....
The Cosworth V8 that Williams used a couple years back pulled 20,000rpm not long after it first ran.
Mostly the engine freeze meant alot of very talented people got sacked. >_<
Speaking of engines..... Bernie is now saying that teams that want to abide by the budget caps (and it's looking more and more like all teams won't have an option) will have engine costs fall outside of the budget caps as well as what we all already knew in regards to driver salaries falling outside the confines of the budget cap.
Yeah well whatever Max & Bernie are smoking they should stop it. The engine proposals they keep coming up with get more & more strange by the week. No they are after something called a universal engine which is to be used across categories.
I have always been a fan of Bernies but I think he has finally lost it.
Edited by djr81
I want to see all the manufacturers walk out and stick with this years rules, instant multi million dollar saving right there. Have a car that runs under the same rules for 3 years, then change a simple vairable like engines, or use of data acquisition, communication to the pits or to and from the pits.
So many ways to make the racing cheaper without re-writing the rule book
Problem is Bernie and Max think F1 is about them. When they come to the realisation that it's about the sport, cars, teams and everything that is made up of those things they might actually pull their heads out of their assholes and stop trying to destroy the sport....
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
