Looks like Massa won't take part in tomorrow's race, hope he has a speedy recovery.
http://img.mtv3.fi/mn_kuvat/mtv3/urheilu/f...2009/755343.jpg
warning, a bit graphic.
+1 to a speedy recovery. I think he's lucky to have got out of that one with his life
  • Replies 2.5k
Posted Images
Felipe Massa's huge qualifying crash in Hungary was triggered when the spring from the third damper on Rubens Barrichello's Brawn came loose. It hit the F60 firstly just in front of the cockpit (right arrow - near the triangular engine cut-off sticker), before then striking the cockpit's side...
How did it bounce up to hit him like it did, when you watch the footage there isnt a car anywhere near him?
Apparantly he has a fractured skull?
Why couldnt this happen to lewis (oops did i just say that out aloud) :banana:
I'd prefer if it happening to YOU. :laugh::):)
Neil.
Good on Webz for stealing 2nd in the drivers championship :angry:
Was funny seeing Flav with briefcase in hand leaving the circuit with about 20-30 laps left and his 2nd driver in 12th spot....I think that says it all for NP career :)
I hope Massa has a speedy recovery...another of those 1 in a million accidents that reminded me of the Surtees one last week or so. After they slowed the footage down and you could see the part strike the car and driver, watching it in real time is scarey as it happens so fast you can't see the spring! It is never good to see a driver hurt like this but is a stark reminder of why you need to pull cars into the pits to rectify things like exhaust pipes hanging by a thread and dangling around on an F1 car...
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
