  • Replies 2.5k
Posted Images
Crashed was an understatement, why would you push that hard on the last lap when he had no hope of catching button. "oh i was going to catch button and use my KERS to get past him on the finish line, just like in the movies"
Also why wasn't he classified as DNF?
Edited by PHaT MR30
I think it's because he was in 3rd place at the time of the accident and he would be the last driver on the lead lap at the end of the race. But still I don't know why he was pushing so hard on the last lap.
Poor Webber, first retirement of the season but it does takes take a big hit on the championship. I'm still watching what's going to happen at Brawn over the last 4 races...will team orders come into play or will Ross Brawn let them slug it out for the championship
On a side note...I can't take Kimi seriously with that shaggy long hair of his...just doesn't suit him.
team orders for Brawn would be to slug it out...after the Renault thing I don't think it would be wise for any team to ask a driver to move aside if the other driver was a legitimate candidate for the WDC.
At the end of the day I don't think Brawn would care who won as long as it was one of their drivers and if they fight it out to the death they're looking at a 1-2 finish in the WDC too.
Honda must be spewing :P
If Honda was still there...then the team wouldn't be where it was - the Honda engine apparently wasn't all that powerful. I remember Ross Brawn saying that the chassis was really good but the he needed a better engine package
I predict the current season will be the high point in Webbers career, with him finishing 2nd or 3rd in the WDC
actually, scrap that; He's on for 3rd or 4th, assuming he doesn't get taken out by n00bs in the opening corners of the remaining races or any reciprocating engine components deciding they want to see what fresh air feels like
Fark hamilton what is going on man! Got a bet on with a mte he will beat kimi on pts this year, i dont want to be paying up either
Im off to the next race in singaopre, hopefully a better result there. Fingers crossed either hamo or webber can win fuhck teh brauns!
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
