  • Replies 2.5k
Posted Images
I am sure if Fisi had of been able to test the Ferrari before switching that it may have been a far tougher decision
An opportunity to drive for Ferrari for an Italian and debut for them in Italy..... Fk man I'd literally give up a nut for that :3some:
Kimi has been doing very well lately.
All R&D is for next season and he is still driving the nuts of that thing !
as for MW....no comment
trulli you bad a$$ loll
as for fisi, mate go bury your head into a pizza or something what the hell was going through his mind leaving the pits.....
Seemed like he was riding a pony instead of a prancing horse !!!!
...what was going through his mind leaving the pits.....
That was great. Heiki almost made up for his average performances in McLarens so far with that one move... almost
What's even more hilarious is when he overtakes a Toyota driver on the last corner of the last race to become the WDC, and makes little Brazillian girls go all teary.
Now THAT'S funny :)
I've always wondered how many $millions that cost McLaren last year.... Anyone know?
like some kind of western suburbs crack addict, im having to check planetf1.com a couple times a day, every day, to see if kimi is joining hammo next year
yeah, I was playing that game at work last week. lol
nothing. Toyota's own telemetry shows Glock was going as hard as he could on his dries, and Hamilton just had better pace on inters.
Either way Lewis is a choker lol, chokes on the last lap, chokes in the last 2 races of the season...ROFL
Had Renault not cheated massa would be champ. You all know that...
/end trash talk
btw kimi I think should be at brawn, because jenson sux hard... That makes 2 English chokers...
Okay, let's play that game:
If we go with the 'what if Renault hadn't cheated?' scenario, if Massa had have received a drive-through penalty for driving off down pit lane with the fuel hose (like He should have); then adding the drive through time to the time lost by the pit crew retrieving the busted fuel hose from the car, there is no way He would have finished in the points anyway.
What's more (and worse for Ferrari fans), is that Hamilton started P2. First and second placed Alonso and Rosberg quite clearly benefited from Junior's shifty self-pwnage (they started 15th and 8th respectively). So if Lewis had have finished in P2, He would have collected 2 extra points (or possibly 4) for that race.
So loser-boy finishes the season at Interlagos 3 points (or possibly 5) behind Hamilton, rather than 1
But it still would have been at least 1 point any way you care to slice it :)
Now can all the bleeding-heart Massa fan-bois finally s.t.f.u about this? Probably not I'd suppose, but it'd just be ignorant of the facts to keep crapping on about it...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
