  • Replies 56
Posted Images
PM Sent
PM replied
G'day, PM sent regarding radiator. Thanks
Pm replied!
Can I grab the Drivers side seat belt assembly please?
Sorry mate, I just sold the seatbelts earlier this week
you have PM :down:
Replied
What about the whole drivers side door?
Hiya, i've got the drivers door shell - it's missing the window motor, door trim and switches. PM me if interested
have you got the side skirts for sale? in good condition?
i can pick up asap !
cheers
PM sent!
Interest in the Set of R33 gts-t stockies with kuhmo tyres. almost brand new / 90% tread, let me know if it's still available. Call me on 0430081199, if I can pickup today it's would be great
pm sent i need
Drivers window switch surround (long black thing the window switch screws into)
Dash surround
posted to brisbane thanks
Any marks or scratches on above items?
  • 3 months later...
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
